idle problem while AC is on
Old Nov 5, 2003 | 09:22 PM
BB6 SH's Avatar
Default idle problem while AC is on
my car is exhibiting idle problems when the AC is on, this problem recently occured the car never had any idle problem of any type before this. when i rev the car at dead stops with the AC on, the car would bog down to 100 rpm then recover at 500 rpm where it should always be, but when the car is in motion everything feels fine, no power loss, vtec feels fine, and also the idle sound a lil rough. what is going on?
plz give fed back.thx...
Old Nov 6, 2003 | 10:50 PM
BB6 SH's Avatar
Default Re: idle problem while AC is on (BB6 SH)
ANYONE?
Old Nov 7, 2003 | 12:28 AM
generask
Guest
Posts: n/a
im not the sharpest tool in the tool shed but id check the cap and rotor and even the spark plugs.....those things could be going bad
Old Nov 7, 2003 | 08:00 AM
Don Napier's Avatar
Import Alliance
check your throttle cable too.
Old Nov 7, 2003 | 08:11 AM
JimBlake's Avatar
Default Re: idle problem while AC is on (egCivicDon)
Clean your IAC valve? The ECU opens that in order to hold the idle steady when the AC clutch engages. Could be sticky or something - not working smoothly.
Old Nov 7, 2003 | 08:11 PM
BB6 SH's Avatar
Default Re: idle problem while AC is on (JimBlake)
the IAC sounds real interesting. anymore thoughts on the IAC?
Old Nov 7, 2003 | 08:29 PM
mel_2kgsr's Avatar
you could advance your ignition timing
Old Nov 7, 2003 | 09:17 PM
dohcter g's Avatar
Default Re: idle problem while AC is on (mel)
I'm with him, My civic hatch did the same thing back in the day and I advanced the ingnition timing a hair and it idled as smooth as can be.
Old Nov 14, 2003 | 09:03 PM
BB6 SH's Avatar
Default Re: idle problem while AC is on (dohcter g)
Old Nov 17, 2003 | 03:48 AM
JimBlake's Avatar
Well, did you check any of those things? Is your IAC valve dirty? Is your timing just a bit off? How old are your spark plugs? We're guessing blind until you tell us more.
Old Nov 17, 2003 | 04:30 AM
urvtecs2slo's Avatar
i have this same problem in my civic, but when i drive with the ac on, i can feel a significant power loss. my car also idles horribly, maybe around 300...almost stalls when i rev it and let off, and my car is an automatic. any advice?
susy76
May 26, 2013 02:38 PM
AnthrPludedriver
May 22, 2007 07:40 AM
BB6 SH
Nov 7, 2003 11:14 AM
riceball777
Aug 18, 2003 10:11 AM
vietboixstunnah
Aug 7, 2003 12:41 PM
