idle
Old Feb 9, 2008 | 05:44 PM
polsky's del sol's Avatar
Default idle
i converted to obd1 today and i'm using a p06. as soon as i started the car it started to idle at three thousand. once it warmed up it would bounce in between 1000-3000 rpms. my friend told me that if i changed my throttle body it would stop the problem. any other ideas?
Old Feb 9, 2008 | 06:37 PM
GhostAccord's Avatar
Default Re: idle (polsky's del sol)
First things first
Vehicle - Make/Model/Year
Engine - code/year
I wouldn't go replacing the throttle body just yet.
Check to make sure that you have all of the sensors plugged in and in the proper locations. IACV, MAP, TPS etc..etc.. Did you do any work on or around the throttle body or intake manifold. If you did check for any disconnected vacuum hoses.
Is the P06 ECU chipped or stock. Buy converting to OBD1 what did you physically change, Just the ECU harness or did you do any engine bay rewiring?
Is your check engine light on?
Old Feb 10, 2008 | 09:29 AM
Default Re: idle (GhostAccord)
97 del sol d16 non vtec. no work has been done other than the harness and obd1 computer
Old Feb 10, 2008 | 11:10 AM
Where did you get the harness?
Find yourself a list/diasgram of ECU pin outs for both of your OBD configurations. Physically verify that all of the swapped pins are in the correct locations. I bought one hat had two of the wires connected to the wrong pins on the ECU.
Old Feb 10, 2008 | 12:13 PM
where can i find one of these diagrams? is it easy to figure out and would i be able to fix it or would i have to buy a new harness?
Old Feb 10, 2008 | 02:35 PM
Before you go tearing into your harness where did you buy it from? Did you buy it used from someone or did you buy it new from a company? If it's new I would contact the manufacturer to see if they have any customer support. If you bought it from someone then you may have to look for ECU pin outs. If you use the search archive function up in the top right of the screen there are a few links around already.
You still haven't answered if the ECU is stock or not or if your check engine line comes on when the P06 is plugged in.
Old Feb 10, 2008 | 02:51 PM
vlang29's Avatar
helpful for idle bounce
https://honda-tech.com/zerothread?id=1979500
Old Feb 10, 2008 | 09:20 PM
Default Re: idle (vlang29)
the ecu is a stock p06 and i do not get any codes when it is plugged in.
dohc4life
May 8, 2011 11:42 AM
FRKWOO
14
Feb 28, 2009 02:34 PM
G-COM
Aug 20, 2007 07:58 PM
si0385.
Dec 15, 2005 07:13 PM
EKtypeRhaTcH
15
Nov 29, 2004 10:47 AM
