Ideling Problem (please help)
Old Sep 13, 2006 | 07:37 PM
Boosted_Coupe's Avatar
Default Ideling Problem (please help)
So my friend just purchased a Skunk2 TB and now he can't seem to figure out how to adjust his idle? He has a 1994 Integra with an LS Vtec TypeR head and and TypeR IM, He is using the orginal throttle cable from his B18b, Would that make a difference at all? His car idle's around 2000 rpm's and we can't seem to figure it out. Any help would be great. Thanks in advanced!
Old Sep 14, 2006 | 12:31 AM
L33TsAbabyEater's Avatar
Default Re: Ideling Problem (SiR_JDM95)
Does the idle fluctuate at all or is it just a constant 2000?
Old Sep 14, 2006 | 12:50 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Ideling Problem (DoraThaMuthaF*ckinExplora)
Did he replace the throttle body gasket when he changed it? Probably a vaccum leak. Or you didn't re-calibrate the TPS correctly.
Old Sep 14, 2006 | 12:54 AM
Default Re: Ideling Problem (JDM_Ej)
if its constant than its probably vacuum like JDM_Ej said from bad TB Gasket or something in that area...
Old Sep 14, 2006 | 05:34 AM
:Andrew's Avatar
i agree with JDM_Ej. did you correctly calibrate your tps (throttle position sensor)
Old Sep 14, 2006 | 02:05 PM
Most of the time it's a constant 2000 rpm, And yes it did come with a new gasket.
Old Sep 14, 2006 | 02:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">re-calibrate the TPS correctly.</TD></TR></TABLE>
How do you do this?
Old Sep 14, 2006 | 10:06 PM
:Andrew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR_JDM95 &raquo;</TD></TR><TR><TD CLASS="quote">
How do you do this?</TD></TR></TABLE>
get a multimeter. with the car turned over to (acc) probe the positive wire on the tps. then use the multimeter to check the voltage. with the throttle fully closed it should read .5v with it opened to full throttle, it should read 4.5v. if it does not read that,loosen the tps and move it around slightly with the multimeter still attached until you get it to read the above voltage.
Modified by :Andrew at 1:46 AM 9/18/2006
Old Sep 15, 2006 | 01:47 PM
Default Re: Ideling Problem (:Andrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :Andrew &raquo;</TD></TR><TR><TD CLASS="quote">
get a multimeter. with the car turned over to (acc) probe the positive wire on the tps. then use the multimeter to check the voltage. with the throttle fully closed it should read .5v with it opened to full throttle, it should read 4.5v. if it does not loosen the tps and move it around slightly with the multimeter still attached until you get it to read the above voltage.</TD></TR></TABLE>
Thank man!
Old Sep 17, 2006 | 09:48 PM
:Andrew's Avatar
no problem also could try adjusting the idle screw on the throttle body.
teggsr925
Mar 27, 2010 09:21 PM
the_dxB16
Mar 13, 2008 10:47 PM
94HONDAHEAD
May 14, 2007 05:34 PM
2fknlo
Sep 13, 2004 01:15 PM
PowderB16
Jul 16, 2004 08:34 PM
