IACV removal problem
Old Dec 30, 2008 | 11:05 AM
Xxcivic99xX's Avatar
Default IACV removal problem
I have a 99 civic Ex, My IACV is bad. I took three of the 4 bolts out. the IACV is on the bottom of the throttle body. Is it nesscessary to remove the Throttle body to get the IACV off?
Old Dec 30, 2008 | 11:46 AM
twentyhurtz's Avatar
Default Re: IACV removal problem
um, your IACV is on the bottom of your throttle body? Thats strange because ever honda i have ever seen had it mounted on the back of the IM using two bolts.
Old Dec 30, 2008 | 12:43 PM
nub's Avatar
nub
y7 and auto y8 IACV is on the throttle body.
You shouldn't have to remove the tb, if you removed the correct bolts it should pop right off
FTNW
Jan 10, 2012 04:39 PM
piggydog
Aug 8, 2010 02:57 PM
Gsr.Turbo'd.Teg
May 7, 2007 03:59 PM
95_red_dc
Sep 11, 2006 09:47 PM
Civic Hybrid
Jun 13, 2006 10:54 PM
