IACV question? HELP PLEASE!
Old Mar 27, 2006 | 01:08 PM
f2m0u5's Avatar
Default IACV question? HELP PLEASE!
PROBLEM FIXED
I got a 99 EK hatch with a OBD1 GSR swap. I reused the stock harness I have, but notice the IACV plug has been removed completely. My question is, can I wire up the IACV to the ECU like its suppose to be and wire it to a IACV plug? I know theres two wires for the IACV, so I guessing one is the IACV wire and a ground wire. Can somebody help me out.
The motors already in the car, so Its hard to look behind the motor and under the intake manifold for the plug because theres no room. Im only throwing a CEL 14 for the IACV also.
Modified by 0LlY at 8:10 PM 4/2/2006
Old Mar 27, 2006 | 04:15 PM
f2m0u5's Avatar
Default Re: IACV question? HELP PLEASE! (0LlY)
anybody?
Old Mar 27, 2006 | 05:20 PM
so lazy's Avatar
Yes you can wire str8 to your ECU. I've done it before for a kid cause he ripped his str8 thru his engine harness. GOOD LUCK! theres like a hole under your battery tray stick it thru there remove the gromet and poke a hole it in for the wire to fit thru..
Old Mar 27, 2006 | 05:50 PM
f2m0u5's Avatar
Default Re: IACV question? HELP PLEASE! (dc2-guy)
but theres two wires? so your saying one wire is a ground wire?? I know for sure one wire goes to the ecu.
Old Mar 27, 2006 | 07:18 PM
so lazy's Avatar
i'll look into the books tomorrow and give you the pin outs.. at your ecu..
Modified by dc2-guy at 11:39 PM 3/27/2006
Old Mar 27, 2006 | 08:10 PM
f2m0u5's Avatar
well i dont need the pin outs for an obd1 harness/ecu.. I need it for an obd2b because thats the harness I'm using w/ a obd2b to obd1 conversion harness.. I think i already found out how to do it, ill let you know thanks for the help also
Old Mar 27, 2006 | 08:21 PM
so lazy's Avatar
no problem at all... anytime..
f2m0u5
Mar 27, 2006 09:19 PM
f2m0u5
Mar 27, 2006 06:44 PM
