IACV advice
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
i am at a crossroad. i am using CBR ITBs and i need to make a decision on whether to keep the valve, or to eliminate it. i can disable it in Neptune.
how much drivability is lost with it gone?
the issue is, i can't simply disable it now and then add it on later, i am making the vacuum log and i either make the provisions for it now (PITA) or forget about it altogether.
cant make a fitting and plug it for future use?
i assume you'll be tuning using alpha-N and not the map? how often do you drive the crx? if it's just a weekend warrior i wouldnt even think twice and delete it.
i haven't driven it in months. i plan on driving it daily. and as far as fabrication goes, i would need to make a plate that accommodates the valve, with its appropriate air routing.
stealth civic
Mar 21, 2004 01:22 AM
