IAC problems help
Old Nov 11, 2008 | 06:19 PM
r1de4life's Avatar
Default IAC problems help
so i have a 91 dx with a b18b that has a auto manifold on it. the car is converted to multi port, when the car is running it makes a loud buzzing noise that you can hear very well, if i close the hole almost all the way in the TB that goes to the iac the idle comes down to normal and the buzzing stops? any one have any idea whats going on or heard anything like this?
Old Nov 14, 2008 | 11:53 AM
r1de4life's Avatar
Default Re: IAC problems help (r1de4life)
no one can shine any light on this? i thought this was honda tech
Old Nov 14, 2008 | 02:55 PM
JNocon's Avatar
First of all, what do mean by "close the hole almost all the way..." Is it close ALL THE WAY, or ALMOST=half and half close/open?
Old Nov 14, 2008 | 03:38 PM
r1de4life's Avatar
Default Re: (JNocon)
the more i put my finger over the iac hole the lower the idle comes down and the buzzing noise stops, and when i completely cover it it shuts off, im guessing its the iac , cleaning it will not fix it. it has got to be broken
Old Nov 15, 2008 | 03:05 PM
JNocon's Avatar
Do you have an xtra one in good working condition? Try that...if that works, then the other one might have a plunger stuck w/ the spring...or like you said it's broken.
Old Nov 16, 2008 | 07:15 PM
r1de4life's Avatar
figured it out my iac was bad due to my tps not having the outside two wires switched around.
edogmb
May 13, 2012 08:34 AM
redrelease
Apr 21, 2006 07:54 PM
Turbo_Mike
Sep 26, 2005 03:32 PM
penney
Mar 30, 2004 08:42 AM
