I WANT 5 LUGS
Can I buy cross drill rotors with 5 lugs and take mine of and put those on? I'm not good with this type of stuff, but I do know that I want cross drill rotors with 5 lugs. Please help a neebie
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. Phil »</TD></TR><TR><TD CLASS="quote">Can I buy cross drill rotors with 5 lugs and take mine of and put those on? I'm not good with this type of stuff, but I do know that I want cross drill rotors with 5 lugs. Please help a neebie</TD></TR></TABLE>
Ahhh if it were only that cheap and easy all of us would be rolling on 5 lugs. Follow tequilakid's advice and search for the topic because I know it has been thouroughly covered before.
You know, with 5 lugs you just have more choises with rims. There are a set of rims that I want and they are 5 lugs. I am going to stick with the 4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. Phil »</TD></TR><TR><TD CLASS="quote">You know, with 5 lugs you just have more choises with rims. There are a set of rims that I want and they are 5 lugs. I am going to stick with the 4
The ITR community will disagree with this. There may be many 5-bolt wheels, but do they have the correct offset?
</TD></TR></TABLE>The ITR community will disagree with this. There may be many 5-bolt wheels, but do they have the correct offset?
From: wudnt u lik 2 no...haha, SO CAL, United States
man just go 5 lug. its so much better. its safer and looks way better. youll even have bigger brakes and all. all is possible. look them up on the internet and do a lil search and youll find some. goodluck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcsurfer8386EF »</TD></TR><TR><TD CLASS="quote">man just go 5 lug. its so much better. its safer and looks way better. youll even have bigger brakes and all. all is possible. look them up on the internet and do a lil search and youll find some. goodluck.
why safer? on the off chance one of your lugs decides to fall off while driving? dumb ***.
</TD></TR></TABLE>why safer? on the off chance one of your lugs decides to fall off while driving? dumb ***.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinsouza »</TD></TR><TR><TD CLASS="quote">
It's safer cause you will have cross drilled rotors which are prone to crack and you will have a modification which is not OEM and has most likely not been done by a proffessional using parts that aren't new and of unknown/questionable origin. Just my 0.02. Do as you want, just don't call it safer.
</TD></TR></TABLE>It's safer cause you will have cross drilled rotors which are prone to crack and you will have a modification which is not OEM and has most likely not been done by a proffessional using parts that aren't new and of unknown/questionable origin. Just my 0.02. Do as you want, just don't call it safer.
TurboCivicR93
Suspension & Brakes
16
Feb 5, 2013 05:29 AM
Toofast2GEN05
Mar 27, 2004 03:16 PM
