I need oil pan torque sequence
Old Jul 10, 2004 | 09:31 PM
See Are X's Avatar
Default I need oil pan torque sequence
I need to know which bolts/nuts to tighten in what order. Also, should I use gasket sealer on both sides of the gasket, on the whole gasket? or just the corners? Would I be fine reusing a gasket thats been on the motor for maybe 3 days?
Old Mar 3, 2005 | 04:37 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: I need oil pan torque sequence (See Are X)
Bump it up
Old Mar 3, 2005 | 04:52 PM
drdisco69's Avatar
Default Re: I need oil pan torque sequence (LSVTEC 91 Civic)
I use hondabond on both sides of the gasket, all the way around. I put the pan in place and tighten all the nuts and bolts finger tight, so they just touch the pan. Then, starting in the middle of one side, I tighten a bolt to the 9 ft/lb spec, then the one on the opposite side. I go back and forth around the pan until i get back to the first one, then I go around one more time, just to double check it. Never had a leak on the many I have done.
You should be ok to reuse that gasket, a few days won't hurt it.
Old Mar 3, 2005 | 05:47 PM
Lord Helmet's Avatar
Default Re: I need oil pan torque sequence (drdisco69)
10 ft-lbs and apply liquid gasket to 4 points on the oil pan. At where the pan starts to curve downward on each end. apply the liquid gasket on both corner top part of the curved section on both sides.
george34
Nov 9, 2016 09:44 PM
_kiid
Mar 2, 2010 05:15 PM
rewerbcrx
Dec 15, 2005 05:34 PM
BlackRocket
Jul 20, 2005 09:45 PM
escocrx
Jan 17, 2003 08:49 PM
