I need help repinning my ECU
Old Feb 12, 2003 | 12:34 PM
wickedEFguy's Avatar
Default I need help repinning my ECU
ok so first of fI have a 90 Si EF and I'm going off of a PR3 and P72 wiring diagram, on the P72 pin (A17 PNK/BLU IAB -IAB Solenoid-), where does it connect to the PR3? I can't find the pin that it connects to, also this is going to sound dumb but what is IAB?
Old Feb 12, 2003 | 12:48 PM
CHEETAH's Avatar
Default Re: I need help repinning my ECU (Ninja_Jc7)
pr3 doesnt not have an IAB .. only P72 gsr and P13 h22a carry those ... thats your secondary butterflies. If you have a gsr in your EF and want to keep your secondaries functional then use an MSD rpm activated switch/
greg
Old Feb 12, 2003 | 01:01 PM
Default Re: I need help repinning my ECU (CHEETAH)
ok hold on I worded that wrong, I'm swapping a C1 into the EF and I'm just using the PR3 wiring diagram as referance since I'm repinning my stock harness, what I need to know is where do I hook up the IAB on the stock harness since I'm going with a P72 ECU?
Old Feb 12, 2003 | 01:29 PM
CHEETAH's Avatar
so you converted your EF interior harness to 92-95 ? or o you know tha tthe P72 won't plug intot he EF harness ? or is someone making you a harness adapter ?
Old Feb 12, 2003 | 02:15 PM
I'm making a harness using my old harness and I'm just sliping the wires together get what I'm saying?
OrangeTeggy
35
Jun 28, 2009 06:10 PM
integra95gsr
Dec 1, 2005 08:51 PM
CoLJeW
Dec 18, 2001 05:54 AM
