I need help!! b16 in an ef whats the problem
Old Apr 6, 2005 | 04:38 PM
b16box's Avatar
Default I need help!! b16 in an ef whats the problem
i have an obd 1 b16 motor with an obd 0 distrubutor in a 91 hatch the car runs perfect ... most of the time. when driving around town the car runs and revs perfectly but when i get on the interstate (speed doesn't matter) for about 15 minutes straight the car starts to sputter and break up , so i put it in neutral and coast for a while and then i can drive again. I have replaced everything that has to do with spark and cleaned my injectors and put in a new fuel filter but i still have the problem any ideas would be greatly appreciated!
Old Apr 6, 2005 | 06:40 PM
blackmagicCRX's Avatar
Default Re: I need help!! b16 in an ef whats the problem (b16box)
do you have both O2 sensors hooked up correctly? Also have you checked your timing?
Old Apr 9, 2005 | 03:33 PM
b16box's Avatar
Default Re: I need help!! b16 in an ef whats the problem (blackmagicCRX)
well i have only one o2 hooked up because of the diff. in the exh. manifold my timing is a little bit advanced on the distributor but my mechanic told me that would not cause my problems. any ideas????
Old Apr 9, 2005 | 05:42 PM
well you definetly need to have both O2 sensors hooked up correctly!!! that caused a lot of problems on my car.
Old Apr 9, 2005 | 06:03 PM
brokenojoke's Avatar
Guarenteed. You need to have both of the O2's hooked up CORRECTLY!
Don't beleive any of the garbage that you can run just 1 O2 on your car.
You need both O2's hooked up correctly! I had the exact same problem you had and it drove me nuts. I bet if when it starts to stumble over itself on the freeway , if you pulled off the road, turned the car off for a few minutes, then started to drive again it would go away. Then a few minutes later it would do it again.
You have to fit your O2 issue.
Old Apr 10, 2005 | 06:27 PM
b16box's Avatar
Default Re: I need help!! b16 in an ef whats the problem (brokenojoke)
that is exactly whats going on!!! i have replaced all kinds of stuff b/c my mechanic swore that is what was wrong but nothing ever worked. now the only problem i have is that i just moved to orlando and i have no clue where to find an ok shop to work on my car. Do you know of any shops in the orlando area?
wasabivtec
11
May 14, 2009 09:53 AM
thebonniesong
33
Apr 25, 2008 06:34 PM
honda_ef9
Jan 21, 2007 09:27 AM
Art701
Jan 13, 2004 03:36 PM
DOHCRX
May 13, 2003 01:50 PM
