Hydrolocked my car???
Old Feb 13, 2003 | 06:54 PM
thaiphob's Avatar
Nikon!!!
Default Hydrolocked my car???
Today i was driving home and i saw a huge puddle in front of me. so i carefully rolled through thepuddle w/o stepping on the gas. then a huge truck drives by and splashed water all over my car . a few moments later my car starts to bog and dies. i had a bad feeling about this so i just turrned off my car.
just wanted to know if i were to drain all the oil out of the crankcase, would this help avoid water damage to my engine some help please!!
Old Feb 13, 2003 | 07:06 PM
sslude's Avatar
Default Re: Hydrolocked my car??? (thaiphob)
did you try starting it up again? did it work? if it did, then it's not hyrdrolocked. im not saying to trya nd start the car, just asking if you did do it before
Old Feb 13, 2003 | 07:07 PM
sslude's Avatar
Default Re: Hydrolocked my car??? (sslude)
BTW, water splashed on your car shouldnt do any damage, your intake has to be completely submerged in water to be hyrdrolocked
Old Feb 13, 2003 | 07:08 PM
the DR.'s Avatar
pull out your spark plugs and put a towel or something over the holes and crank it over... that is unless you've already tried cranking your car and killed the engine..
Old Feb 13, 2003 | 07:14 PM
cstgrd's Avatar
Default Re: Hydrolocked my car??? (SlicedBread)
same thing happened to me one time I pulled off the dist. cap and dried everything and it started right up and ran fine I don't know how water would get in your oil from that cause if it did than every time it rained hondas wouldn't run
Old Feb 13, 2003 | 07:15 PM
Regular Series's Avatar
Not necessarily. If your distributor got wet it can cause your car to stall. FYI, if your filter is completely submerged it won't matter how slowly you drive. Even an idling engine can draw water all the way to the combustion chambers without much trouble.
Old Feb 13, 2003 | 07:16 PM
Desslok's Avatar
Exactly, you want to get the water out of the combustion chamber. DO NOT try to crank it without taking out the spark plugs.
Old Feb 13, 2003 | 08:43 PM
thaiphob's Avatar
Nikon!!!
i took out all the spark plugs and found lots of water in the #1 cyc was hella flooded. so i sucked up as much water as i can and cranked it. nothing so i tryed it again. nothing RIP to my motor i guess...
Old Feb 14, 2003 | 06:39 AM
kikicamacho's Avatar
Dude, that bites. I drove through a large puddle on 15th ave and Indian School yesterday. My wife's Civic doesn't have a Cold Air just a short ram but I was sweating bullets through the intersection. Where was this small lake?
Old Feb 14, 2003 | 08:34 AM
PhatOptimo's Avatar
You probably bent a rod. Compression test it.
motingwedennis
May 4, 2018 05:09 AM
7azhar7
Honda Civic (2001 - 2005)
Dec 1, 2011 04:03 PM
scrap1ngsr
Apr 26, 2003 06:32 PM
Diegolude
Apr 5, 2003 04:02 PM
Muad'Dib
Jun 15, 2001 03:04 PM
