Hydro tranny in my CRX?
Old Dec 9, 2003 | 08:19 AM
Jdm_Rice_Monster's Avatar
Default Hydro tranny in my CRX?
I bought a hydro tranny for my crx and have been searching for the best way to go about using it. I found very little info on it. Should I buy a kit and use the cable, or change out the pedal assemble and run hydro lines. Also what mount do I use since I am using a place racing mount kit and cross member. Any info will help, thanks.
Old Dec 9, 2003 | 08:46 AM
CHEETAH's Avatar
Default Re: Hydro tranny in my CRX? (Jdm_Rice_Monster)
the hasport kit is best, it comes with the tranny mount and clutch cable assembly kit to convert.
Greg
Old Dec 9, 2003 | 08:52 AM
Default Re: Hydro tranny in my CRX? (CHEETAH)
yeah but will I be able to use that hasport mount with my place mounts I already have. Does place make a kit?
Old Dec 9, 2003 | 11:45 AM
also what do I do as far as the vss. My car is obd1 is there a way to hard wire that 3 wire sensor, or do you use the speedo cable.
Old Dec 9, 2003 | 09:23 PM
ttt
Old Dec 10, 2003 | 10:34 PM
any more help
Old Dec 15, 2003 | 08:11 PM
ttt
Old Dec 15, 2003 | 08:24 PM
keithg's Avatar
I don't think the hasport tranny mount is compatible with the place racing left and rear mounts. Hasport does sell the cable/hydro thingy separatly from the mounts.
Have you seen this thread on the hasport kit?
https://honda-tech.com/zerothread?id=650859
Old Dec 15, 2003 | 10:54 PM
Default Re: Hydro tranny in my CRX? (keithg)
Do you know if the hasport mounts make the motor sit more foward as opposed to the place kit. Because I can afford to lose anymore space up front for turbo room.
Old Dec 16, 2003 | 12:31 AM
Zerob16eg's Avatar
hey man there is a way to convert your cable speed-o to a electronic one. my friend has a rex and he put a gsr cluster in it. i think he ran a wire from the ecu to the cluster. if your interested i'll ask him how he did it and reply on your thread. peace
Old Dec 16, 2003 | 11:35 AM
Default Re: (Zerob16eg)
yeah dude the more info the better, thanks.
Old Dec 16, 2003 | 04:40 PM
CrazyKoreanCrx's Avatar
Default Re: (Jdm_Rice_Monster)
The hasport motor mount your engine will be back more towards the firewall and with place racing mounts I dont know where the engine sit maybe in the middle. But you have the crossmember from placeracing so you shold have extra room for the turbo and with the hydro convertion just but the kit from hasport should be like 275 or something like that.
And are you converting your obd-0 to obd-1?
Old Dec 18, 2003 | 07:55 PM
Default Re: (CrazyKoreanCrx)
its already obd1 so I may be abe to just wire the vss from the ecu...I guess. but if the hasport mount kit sits the engine more towards the firewall I may just go with it.
Old Dec 20, 2003 | 11:24 AM
N E more info
Old Dec 21, 2003 | 07:39 PM
Zerob16eg's Avatar
hey man my friend said that all you need to do is find the wire on your cluster that recieves the input from the vss and run a wire from your cluster to the ecu (you will need to find a wiring diagram and find the wire that represents the vss). basically you are running a code 17 because you bypassed the ecu input. if you have any other questions then hit me back. peace
Old Dec 21, 2003 | 07:42 PM
I havent dont the conversion yet....I am going to us a newer gsr cluster....hopefully.
FullRaceHonda
Oct 30, 2006 07:44 PM
SomeDude56
Dec 26, 2005 11:13 AM
90teg
Aug 1, 2005 10:32 AM
Spoonin
Jan 27, 2004 09:20 AM
jdmjopey
12
May 1, 2003 04:34 PM
