HOW TO:::wire 1wire O2 to a four wire O2...?
Old Mar 17, 2003 | 01:05 PM
dfoxengr's Avatar
Default HOW TO:::wire 1wire O2 to a four wire O2...?
i am a flaming idiot...i looked and do have the 4wire one..lol..the guy that did my swap told me i had 1 wire..sorry
[Modified by hybridvteceg, 1:14 PM 3/18/2003]
Old Mar 17, 2003 | 01:13 PM
sgT's Avatar
sgT
Default Re: HOW TO:::wire 1wire O2 to a four wire O2...? (hybridvteceg)
4 wires
signal
sensor ground
heater power
heater ground
just connect to corresponding ecu pinouts
Old Mar 17, 2003 | 01:19 PM
dfoxengr's Avatar
Default Re: HOW TO:::wire 1wire O2 to a four wire O2...? (sgT)
so on the back of the 1 wire sensor theres a place for 4 wires?
Old Mar 17, 2003 | 01:20 PM
dfoxengr's Avatar
bacause since its a 1wire to begin with, its not internally heated....
Old Mar 17, 2003 | 02:50 PM
Katman's Avatar
i have a single cam O2 sensoron an LS motor, and need to know how to hardwire it into the ECU to make it like a four wire sensor? thanks
after searching and inferring::::::do i just make the one wire coming off of the sensor into 2 by splicing 2 wires to it, then run those 2 wires to the ecu directly???
What year is your car ?
If its an 88-91 civic/crx or 90-91 integra, I believe you'll need to upgrade to OBD1 or 2 in order for the ecu to look a 4-wire 02.
88-91 ecu's don't look for a 4-wire 02, only single wire, unless you have some standalone 4-wire 02 system ....
Old Mar 17, 2003 | 05:33 PM
dfoxengr's Avatar
Default Re: HOW TO:::wire 1wire O2 to a four wire O2...? (Katman)
nah man...92 hatch...the single wire is the O2 signal...so dont i only have to connect that to the White (signal) wire at the ECU...?
Old Mar 17, 2003 | 09:10 PM
Katman's Avatar
ok, so you own a 92 CX, eh?
If you're down to get a used engine harness, pick up a used 92-95 DX 5speed harness, which will already have the 4-wire 02 embedded into the harness. It will then be plug n' play, ie. you wont have to wire anything 02 related to your ecu. If you go this route, make sure you have a 4-wire 02 also
Old Mar 18, 2003 | 02:43 AM
dfoxengr's Avatar
no i hvae a dx, and its only 1 wire
Old Mar 18, 2003 | 09:06 AM
CHEETAH's Avatar
some of the 92-95 that came with 1 wire o2 can be easily converted with the Si or EX harness or even del sol S for 4 wire operation.
greg
Old Mar 18, 2003 | 09:13 AM
dfoxengr's Avatar
Old Mar 18, 2003 | 11:03 AM
Katman's Avatar
hah rad...well yer set then.
Old Mar 18, 2003 | 11:07 AM
raene's Avatar
Not to jack the thread, but is there any way to hook up a 4-wire O2 safely to a 1-wire O2 non-OBD setup? Reason I ask is the different O2 sensor placement, I'm not sure with the engine heat and internal heater on the O2 sensor going off switched power it would burn out that much quicker on a B16A.
Old Mar 18, 2003 | 11:17 AM
Katman's Avatar
Default Re: HOW TO:::wire 1wire O2 to a four wire O2...? (raene)
well....like I mentioned above, I believe you need to have an ECU(92+) or some stand alone system that looks for a 4-wire 02 to take advantage of 4-wire 02 sensor if I'm not mistaken.
Old Mar 18, 2003 | 01:16 PM
dfoxengr's Avatar
heres how it went down,..its an LS swap, with a CX engine wire harness...thats y he said 1 wire O2..DUH...!! so when i discovered the 4 wire sensor i was all confused..and followed these simple directions...
HOW-TO...lol everyone knows...
1 black and green spliced together groundedother black to ignition switch
white to white O2, which i just connected to the CX O2 wire which is single white anyways...lol..
Product...test jumped it and no codes regarding the O2..YAY
jDMJeRk
Oct 3, 2019 08:19 PM
almostjdmeg
10
Jan 6, 2009 03:35 PM
tibss
Jan 21, 2008 09:52 AM
H23vtecEG
Apr 4, 2003 08:12 AM
Tony the Tiger
Oct 23, 2001 10:55 PM
