how to use my itr compressor on civic?
Old Jun 29, 2003 | 07:35 PM
turkdog's Avatar
Default how to use my itr compressor on civic?
I have a 00 jdm itr motor. It came with a compressor on it. My civic right now does not have any freon in the a/c system. I want to take it off and use my itr compressor. Will it match the a/c line or not. And can you bend the a/c line to get the compressor to fit?
Old Jun 30, 2003 | 01:34 AM
1titesol's Avatar
Default Re: how to use my itr compressor on civic? (turkdog)
First you need to check to see if your stock civic is R34 or R12. There should be a silver sticker inside the engine bay telling you. If it's R34 your half way there(like mine). I had to first fabricate an ac line to the compresser, it busted eventually. Then we had to bend an ac line from a dohc del sol . If it's R12 you need to change the condenser also, or you can use adapters to make them work together.Available at honda.
prime-R
Jul 3, 2010 04:42 AM
traxxasx
Mar 1, 2009 07:31 PM
93integrastock
Aug 30, 2007 06:25 PM
BanUglyImportModel
Jul 3, 2003 07:42 AM
turkdog
Jun 30, 2003 01:36 PM
