How to upgrade fuel pump wiring and relay
Old Oct 13, 2008 | 09:33 AM
Quickridez_3's Avatar
Default How to upgrade fuel pump wiring and relay
im upgrading to dual walbros and heard you should upgrade the wiring and add a relay. can someone help show me how to do that and some pictures thanks
Old Oct 14, 2008 | 03:26 PM
SlowReaction's Avatar
Default Re: How to upgrade fuel pump wiring and relay (Quickridez_3)
Search the drag forum there pictures. Its pretty easy to do just need some relays and 10 or 12 gauge wiring. What part of Seattle are you in? Maybe I can help you.
Old Oct 14, 2008 | 03:58 PM
mmuller's Avatar
Mad Scientist
Default Re: How to upgrade fuel pump wiring and relay (SlowReaction)
use the power to pump to turn on the relay, then run a 10 wire to the battery and ground the pump on a good point.
Old Oct 14, 2008 | 10:41 PM
close to southcenter kent renton area. which wires is it the ones at the top of the floorboards under the carpet or the actual ones that are between the floorboard and gas tank. do you have a pic of yours? does it still turn on like factory or does it have a toggle switch to turn on?
Old Oct 14, 2008 | 10:47 PM
I dont have picture of mine by i'll try to get some. Mine turns on like factory. The relay is turned on by the ecu. 10ga from battery to relay and 10ga from relay to fuel pump. Relay is mounted behind the passenger kick board. I'm going to do a dual walbro also but i will moving the relays behind the rear plastics.
Old Sep 27, 2014 | 10:59 AM
OMG_ej2's Avatar
Hi guy i am new to this site i have some questions What amperage relay do you use i know its 4 pin, also what gauge wire should i use ? I am trying to get the most out of my stock civic pump, i was thinking 12?and should i also upgrade the 12v wire coming from the ecu going to the relay aswell?
Old Sep 27, 2014 | 11:26 AM
Tyler Dirden's Avatar
I am Jack's...
Here is a link to an old thread of mine:
https://honda-tech.com/tech-misc-15/...t-1-a-3145027/
I have found that most Honda tanks have a very stout through wire connection made of brass. This can certainly handle much more power and I'll throw a few pics in to show you how easy it is to add 10 or 12 gage wires directly to the pump connection. The real problem is fuel delivery through the banjo bolt. I hope you upgrade that like in the thread link.
Old Sep 27, 2014 | 01:59 PM
OMG_ej2's Avatar
Thanks for the pics.yea i am gonna drill the whole on the side of the banjo bolt bigger
Old Mar 24, 2015 | 05:43 PM
wes22's Avatar
I hate to bump this old thread but i have everything done beside the ground on the fuel pump clip, if i do the 10g wire from the clip and ground it to the car, then do i just tape the ground on the harness? Or do i just reuse the ground on the harness to clip, im using the walbro 450
Lmgrcivic
Apr 7, 2010 01:30 PM
mr_hahn73
15
Oct 21, 2007 10:17 PM
Reelizmpro
Jul 10, 2005 06:33 AM
spencedogg
Aug 29, 2003 05:52 PM
