how to time a motor w/out the flywheel mark?
Old Sep 21, 2006 | 03:53 AM
fastludeh22's Avatar
Default how to time a motor w/out the flywheel mark?
i have an old school clutch masters flywheel that doesnt have a timing mark on it. i remember somewhere explaing a way to set the base timing without that mark. maybe draw line on the crank pully? anyone know what im talking about?
Old Sep 21, 2006 | 09:02 AM
thesmogman's Avatar
Default Re: how to time a motor w/out the flywheel mark? (fastludeh22)
Here you go.. first remove the #1 plug and the dizzy cap.
Note position of #1 plugwire on cap and point rotor to that spot. Now take a pencil or what ever you like to use, and stick it into the #1 plug hole and rest it on the top of the piston. rotate crank until you see the pencil top out.
So with the rotor pointing to #1 and #1 cylinder at top this is TDC.
Make a mark on the pulley and a reference mark on the timing cover or, or, or, where ever you can.
Now that you have the TDC marked you need an adjustable timing light that you can dial in the advance/retard needed for your motor.
Old Sep 21, 2006 | 02:52 PM
JDM94EG28's Avatar
Default Re: how to time a motor w/out the flywheel mark? (thesmogman)
either the way person said on top of me..or take your spark plug out stick something long and skinny down to the piston and turn the pulley untill you hit tdc...
Old Sep 21, 2006 | 03:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">Here you go.. first remove the #1 plug and the dizzy cap.
Now that you have the TDC marked you need an adjustable timing light that you can dial in the advance/retard needed for your motor.</TD></TR></TABLE>
thanks, i thought it was something like that. then say i want 15 degrees, i just set the timing light to 15 and turn the dist till the lines match up again, correct?...
Modified by fastludeh22 at 6:27 PM 9/24/2006
Old Sep 24, 2006 | 03:31 PM
PrecisionH23a's Avatar
If you are referencing with 1 being at TDC I would highly recommend using a dial to measure the upmost point thus verifying TDC. The screw driver deal works with setting valve lash and leakdown tests... but being off a few degree's for timing could lead to bad things.
Old Sep 25, 2006 | 08:25 AM
thesmogman's Avatar
That would be correct.
gacinaz
Jan 1, 2012 07:04 AM
ayavner
May 28, 2008 03:07 PM
dvp95
Aug 21, 2003 07:45 AM
boomslang
Nov 30, 2001 06:48 AM
bgod
Jul 23, 2001 06:37 AM
