How to test CKP, CKY, TDC Dizzy Sensor on OBD2a
Old Feb 14, 2004 | 04:15 PM
bossman032's Avatar
Default How to test CKP, CKY, TDC Dizzy Sensor on OBD2a
96-98 Civic
how can I test these dam sensors on the ecu please help me out I am getting code 4 I tried everything in my power
Old Feb 14, 2004 | 05:33 PM
BigBlockCRX's Avatar
New User
Default Re: How to test CKP, CKY, TDC Dizzy Sensor on OBD2a (bossman032)
you test it the same way as you would test it for OBD1 , so go on google and do a obd1 honda manual search
Old Feb 15, 2004 | 09:37 PM
500hpsi's Avatar
A good engine lab scope. I have cost me $5,000. interro unit. and I made 80,000 this year with it. If you live in the seattle area I can help.
$60 dollar an hour flat rate time.
Old Feb 15, 2004 | 09:43 PM
bossman032's Avatar
Default Re: How to test CKP, CKY, TDC Dizzy Sensor on OBD2a (500hpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 500hpsi &raquo;</TD></TR><TR><TD CLASS="quote">A good engine lab scope. I have cost me $5,000. interro unit. and I made 80,000 this year with it. If you live in the seattle area I can help.
$60 dollar an hour flat rate time.</TD></TR></TABLE>
LOL
I will give u 50cents plus tax
Old Feb 16, 2004 | 05:40 AM
EE_Chris's Avatar
Honestly, you do need a O'scope.....that IS the only way to really know if they are functioning correctly or not.
The Helms only outlines a procedure for checking their resistance. There are two parts to the sensor; the pickup (which you would measure) and the magnet (which you can't measure). Also to note, if the bushings were worn it would show up on the O'scope, but you would never measure it with an ohm meter.
So unless you've got a meter to do this simple check, replacement is your next option and at ~250 for the cage (because you can't replace individual sensors) its an expensive option.
Old Feb 16, 2004 | 06:41 AM
500hpsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">
LOL
I will give u 50cents plus tax </TD></TR></TABLE>
sure come on down! how about 49 cents and I'll pay the tax.. LOL
Old Feb 16, 2004 | 06:44 AM
500hpsi's Avatar
Default Re: How to test CKP, CKY, TDC Dizzy Sensor on OBD2a (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Honestly, you do need a O'scope.....that IS the only way to really know if they are functioning correctly or not.
So unless you've got a meter to do this simple check, replacement is your next option and at ~250 for the cage (because you can't replace individual sensors) its an expensive option.</TD></TR></TABLE>
well you could do a resistance test. However, resistance test are not accurate enough and can give you false results. A scope is more accurate. You can see what it is doing.
Old Feb 16, 2004 | 11:02 AM
bossman032's Avatar
I fixed the problem like yesterday soo thanks for the replys.
StockDC2
Northwest
Oct 22, 2008 02:29 AM
SlammedDC2teg
Oct 14, 2005 05:32 AM
hatchattak
Apr 1, 2004 07:51 AM
B00ST2nR
Audio / Security / Video
Jan 29, 2003 03:46 PM
