How to tell Head gasket or Head?
Old Jan 24, 2002 | 02:59 PM
KoRE's Avatar
Default How to tell Head gasket or Head?
How can you tell if you blew your head gasket or you cracked or warped your head? is there any distinct symptoms that would point out the problem?
Old Jan 24, 2002 | 05:46 PM
flymecourageously's Avatar
New User
Default Re: How to tell Head gasket or Head? (KoRE)
check spark plugs for oil or coolant is your oil tan or milky color .inspect out side of block for external signs of leakage
Old Jan 24, 2002 | 08:26 PM
bob01721's Avatar
The best way to tell is with a compression test. If two adjacent cylinders have low compression, that's usually an indicator of a blown gasket.
To find a warp, you'll need to remove the head and check it with a straight edge and a feeler gauge. To find cracks, you'll need to use a chemical dye. You spray it on the head, and then you spray a developer over the dye. Cracks will show up as bright red lines.
Old Jan 24, 2002 | 08:29 PM
HaUTSaauce's Avatar
New User
compression test
Old Jan 30, 2002 | 11:32 AM
gokooljapan's Avatar
i need more info on your problem....like does it overheat all the time, does your famn turn on, does you car smoke...etc,.......does it overheat when you drive in freeways?
peace
Old Jan 30, 2002 | 11:35 AM
JG Luder's Avatar
Default Re: How to tell Head gasket or Head? (gokooljapan)
are you asking how to tell if you have a cracked head or blown head gasket, or how to tell the difference between the two?
SolScifen
18
Jan 7, 2012 04:49 PM
bruisedcivic
Jul 16, 2011 12:29 PM
jdmitrdc2
Apr 15, 2009 11:31 AM
new_climber
12
Jan 13, 2009 09:08 AM
civic_jdm
Feb 17, 2005 07:49 AM
