how to tell difference in b series cranks
does anyone have a link that shows how to tell the difference in b series cranks? specifically the difference in gsr and ls. i just need to know how to tell which one i have. i need this info asap. thanks!
If you have a gsr and a ls you can tell by the rod journal width.The gsr journal is shorter.It should be about twice the width of the rod big end plus about .015".It would be nice if they had p72 or pr4 but they don't.
i found a good way to tell. the gsr and typer's outer edge of the counter weight has been machined flat on all of the counter weights. the LS is only machined on the next to last ones on each end and the two center ones. also, the type r has more material in each lobe. it is kinda hard to explain without a pic, but the easiest way to tell is that the type r has a big raised letter R on it. kinda hard to miss.
