How to pass New York emissions test?
Old Mar 22, 2005 | 05:30 AM
turbotegra's Avatar
Default How to pass New York emissions test?
Fellow New Yorkers or others,
I have a '99 Integra vtec turbo. The ECU was changed from OBD-II to OBD-I to accomodate programming and engine management with the turbo.
Given the new NY emissions tests, all '97 and later cars get plugged into a computer which connects to the DMV HQ in Albany. I am expecting an automatic FAIL when the DMV computer expects to be connected to an OBD-II ECU and finds an OBD-I instead.
Has anyone encountered this problem? What is the work-around to get it to pass?
I have considered refitting the OBD-II just to get it through the inspection, but the local mechanic tells me that it will fail unless 'x' amount of miles have been logged by the ECU at various speeds. That means I have to drive it for a while with the OBD-II installed. But I would have to stay completely 'out' of boost as the OBD-II can't handle MAP/MAF readings above atmospheric pressure and I don't want to risk damage.
Anyone "been there/done that"? Pointers to previous posts also appreciated. My search turned up nothing.
Thanks!
Modified by turbotegra at 8:56 AM 3/22/2005
Old Mar 28, 2005 | 06:07 AM
turbotegra's Avatar
Default Re: How to pass New York emissions test? (turbotegra)
Help! Time is running out. Inspection to be done before the end of the month. Any suggestions?
Old Mar 28, 2005 | 11:18 AM
rick97civic's Avatar
just failed one today....still trying to figure out what to do. got a 97 civic with an obd1 b16....its not looking good...
Old Mar 28, 2005 | 02:28 PM
no matter what you do, you have to have an obdII ecu. otherwise it will come up saying that the computer cant communicate with the ecu, therefore failing the inspection. so im screwed...know anyone who wants a car?
Old Mar 28, 2005 | 03:48 PM
bennyfizzle's Avatar
lol...i'm sorry, i have no idea...but i just can't believe its now harder to pass inspection in NY than it is in CA...lol
Old Mar 28, 2005 | 04:48 PM
DIFFUT'S INC.'s Avatar
Default Re: (bennyfizzle)
i know
Old Apr 12, 2005 | 05:00 PM
fastfour's Avatar
Default Re: (DIFFUT'S INC.)
In Seattle if they plug in and it doesn't read they just test the OBDII car the same way they do the OBDI cars------->on the rollers.
k0shi
Oct 4, 2013 09:33 AM
team_ibR
May 27, 2010 02:53 PM
Sinology
Oct 20, 2009 03:57 PM
turbotegra
Mar 29, 2005 08:25 PM
trustbuddy
Apr 22, 2003 10:15 PM
