How often do you change spark plugs?
Old Nov 19, 2001 | 01:29 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default How often do you change spark plugs?
1. I'm trying to get an idea how many miles you log before you change plugs? My plugs look about the same at 10K miles vs 30K miles.
2. Platinum tip plugs are suppose to last long. Some say 100K. What do you think? Any real world experience?
Old Nov 19, 2001 | 01:43 PM
Agamemnon's Avatar
New User
Default Re: How often do you change spark plugs? (GoLowDrew)
I just replaced my plugs at 89k but im not the first owner so im not sure on the life. I had NGK platinum in before, and i replaced them with the same ones, they'll last quite a while but theyre gonna run about 15$ each Can.
I think Honda uses platinum tips from the factory, but im not sure on that...
Old Nov 19, 2001 | 03:32 PM
Rice_Boy's Avatar
Default Re: How often do you change spark plugs? (Devin)
check out clubsi.com see if ur spark plugs look like any of the ones at their site! then change em accordingly!
rice boy
Old Nov 19, 2001 | 03:39 PM
Max GSR's Avatar
My first set went 60k miles with no problem. Since then, I've gone another 30k miles and changed them twice, but more for change in heat range, not because they were worn out. Oh, I use only NGK platinums.
Old Nov 20, 2001 | 04:17 AM
Mista Bone's Avatar
D Tranny Guru
Before I started using NOS, I changed plugs once a year in the spring as part of my AUTOX tune-up. I would also change the oil and brake fluid. Lube all the poly bushings, etc.
BTW at $8 for for NGK plugs, once a year is pretty cheap.
Old Nov 20, 2001 | 11:26 AM
Spade's Avatar
Every 30K is what the rule book says
Old Nov 20, 2001 | 02:05 PM
John's Avatar
New User
Default Re: How often do you change spark plugs? (Spade)
Well, I usually do them after every 10K miles just b/c no matter how many times I tune my V-AFC, I do something else that will richen up the A/F ratio too much... and NOS loves new plugs too...
Old Nov 21, 2001 | 10:44 AM
Jackson's Avatar
Default Re: How often do you change spark plugs? (DunReit)
acura uses them only in the gsr, not the ls. not sure about si though
Old Nov 21, 2001 | 10:45 AM
Crazydave's Avatar
Default Re: How often do you change spark plugs? (Jackson)
30-40k
lawrencelomanon
Honda CR-V & Element
Nov 15, 2017 10:37 AM
StockAccord
12
Aug 24, 2009 09:53 AM
2k1 GSR
Jan 12, 2003 02:33 AM
paulyman
Feb 25, 2002 12:13 AM
HX_Guy
Oct 23, 2001 08:19 PM
