how much more will itr cams giveyou
Old Apr 27, 2003 | 06:41 PM
untitled's Avatar
Default how much more will itr cams giveyou
how much more power will itr or the ctr cams give me over the stock b16a's. will they be decent cams with light nitrous shot too?
Old Apr 27, 2003 | 06:42 PM
eg6ajk's Avatar
Default Re: how much more will itr cams giveyou (88crx91integra)
depends on the motor and many other variables. but usually about 3-7whp can be seen without much tuning.
Old Apr 27, 2003 | 06:52 PM
lazy bum shaughn's Avatar
It's a nice gain. You will notice a bigger difference over the first generation B16 opposed to the second generation since the first gen has weak cams.
Old Apr 27, 2003 | 06:54 PM
untitled's Avatar
Default Re: how much more will itr cams giveyou (lazy bum shaughn)
so the 2nd gen b16 cams have higher lift duration or what. what do you mean by weaker. i thought they were the same.
Old Apr 27, 2003 | 07:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">so the 2nd gen b16 cams have higher lift duration or what. what do you mean by weaker. i thought they were the same.</TD></TR></TABLE>
I dont mean physically weaker, but the first generation B16's cams have a weaker profile, and a smaller throttle body.
Old Apr 28, 2003 | 12:45 PM
untitled's Avatar
well i am going to run the b18a throttle body on the first gen b16. are they the same size? also go into more detail about the differences in first gen b16 cams and second gen b16 cams. more less lift duration. also is there a site with all these specs?
Old Apr 29, 2003 | 08:24 PM
granada_sun's Avatar
I just swapped in 01 ITR cams for the stock b16's, and the car seems to dip at vtec a lil for a second, but then rips all the way to redline, a lil more aggressive than the stock ones did....dyno this weekend tho....
Old Apr 29, 2003 | 08:40 PM
tmekjian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">will they be decent cams with light nitrous shot too?</TD></TR></TABLE>
i am interested in this too...i have a GSR and i am throwing ITR cams in it...can i spray like a 50 shot and still be safe???...anyone know??
Old May 2, 2003 | 09:27 AM
untitled's Avatar
Default Re: how much more will itr cams giveyou (Dark_Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark_Sol &raquo;</TD></TR><TR><TD CLASS="quote">I just swapped in 01 ITR cams for the stock b16's, and the car seems to dip at vtec a lil for a second, but then rips all the way to redline, a lil more aggressive than the stock ones did....dyno this weekend tho....</TD></TR></TABLE>
let me know how that dyno goes would ya?
Old May 2, 2003 | 10:02 AM
Kataku2K3's Avatar
All 2nd Gen+ B16A's and B18C1's run the same spec cams... It's the P72 cylinder heads rocker ratio which increases the valve lift ever so slightly over the PR3... 2000+ ITR/CTR IN cam is all you really need... I've gotten ~1whp sometimes adding in the EX after... Just my $0.02... Peace
e she i
Dec 3, 2006 01:31 AM
riceball777
Feb 9, 2004 06:24 AM
SuperCivic
19
Jun 28, 2002 07:09 PM
InfamousRS
Jun 16, 2002 09:18 PM
juicy.koreans.suck
Mar 7, 2002 07:29 PM
