how much does hondata cost?
Old Jan 4, 2003 | 12:32 PM
Propulsion's Avatar
Default how much does hondata cost?
Im debating between hondata and kenji's ecu for NA b18c, but Im not sure exactly how much hondata would cost.
I know ill need a obd1 ecu + hondata module+ conversion harness+ tuning,
Im I missing anything else? How much would that add up to be?
Old Jan 4, 2003 | 01:04 PM
eg6ajk's Avatar
Default Re: how much does hondata cost? (SilverCIVIC96)
it all depends on how far you're taking the swap. if the motor will be fully built with many one of a kind parts then definatly hondata. otherwise a chipped ECU will suffice
Old Jan 4, 2003 | 02:07 PM
LS-hatch's Avatar
edit: found a better price page.
http://www.hondata.com/prices.html
[Modified by LS-hatch, 6:16 PM 1/4/2003]
Old Jan 4, 2003 | 03:06 PM
87sivtec's Avatar
Default Re: how much does hondata cost? (LS-hatch)
http://www.revscene.net/forums/showt...threadid=97033
See the thread for a Stage 3B for the B18c. A friend of mine is selling it.
Old Jan 5, 2003 | 09:41 AM
Propulsion's Avatar
okay, I checked the hondata prices page, but Im really confused, there is so much stuff, which one will I need? this is just a stock b18c, but I might replace the block w/ a built b20vtec block later. no boost btw
Old Jan 5, 2003 | 12:27 PM
charjacq's Avatar
New User
You could always just start off with a chip and work from there. Hondata is great, but hella expensive! I can do most of the tuning you can do on hondata with only a chip, without the fancy options (wish I had those though).
Old Jan 6, 2003 | 01:03 PM
Propulsion's Avatar
Default Re: how much does hondata cost? (charjacq)
what kinda tuning w/ a chip? I heard most just dump a bunch of fuel and end up w/ horrible gas milage... btw, Im not really interested in hondata's fancy options, just looking for timing/air fuel/ vtec tuning.
Old Jan 6, 2003 | 01:12 PM
LsVTeCTuRBo17's Avatar
Do some research on the costs. You can probably find an obd1 on ebay for 200-250. The harness will be another $200 and your looking at the s200 module for $295. I would also recommend datalogging option for another $200. You don't need all that other stuff, All that extra stuff is for your tuner not for you. And don't listen to others about a upgrading your stock chip. If you want engine reliability, especially on a turboed motor, and your motor to last as long as possible, make sure to get either hondata, aem, or even a piggy back like V-AFC.
[Modified by LsVTeCTuRBo17, 2:15 PM 1/6/2003]
Old Jan 7, 2003 | 12:38 PM
Propulsion's Avatar
Default Re: how much does hondata cost? (LsVTeCTuRBo17)
thanx LsVTeCTuRBo17, that was exactly the info I was looking for, thanx for the break down of the costs.
DXK Eg
Jan 29, 2005 07:49 PM
nsxjr2
Jul 17, 2004 11:53 AM
speedyonez
Oct 20, 2003 06:49 PM
deeweezy
Mar 15, 2003 05:10 PM
evo75
Jun 17, 2002 04:46 AM
