how to install Hondata S300
Old Dec 22, 2005 | 04:06 PM
kaj's Avatar
kaj
Default how to install Hondata S300
mine came with no instructions and their site doesn't seem to have any either. anyone know of a way i can find to solder all these connections? thanks.
this is going into a USDM P72 that is already socketed for an S200
thanks
Old Dec 22, 2005 | 04:40 PM
SVOboy's Avatar
http://www.hondata.com/s300socketing.html
Old Dec 22, 2005 | 04:42 PM
SVOboy's Avatar
Default Re: (SVOboy)
And this: https://honda-tech.com/zerothread?id=1348415
Good luck
Old Dec 22, 2005 | 05:04 PM
drdisco69's Avatar
Default Re: how to install Hondata S300 (kaj)
Yeah, you basically replace the socket with pins so that the S300 can plug into them.
Old Dec 23, 2005 | 08:13 AM
kaj's Avatar
kaj
i must be f'ing blind. thanks, guys. you have no idea how much this helps!
Old Dec 23, 2005 | 08:16 AM
SVOboy's Avatar
No prollem, good luck.
Old Dec 23, 2005 | 08:18 AM
kaj's Avatar
kaj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">And this: https://honda-tech.com/zerothread?id=1348415
Good luck</TD></TR></TABLE>
so is chipping a p72 the same as a p28??
also is EVERYTHING the same so all i gotta do is remove the s200 socket and install the pins for the 300 to mount to? then change the socket where the s200 cable connected? is it really that simple? i'll go read up on this stuff and maybe call hondata. if that's all that's holding me up, i'll do it myself.
Old Dec 23, 2005 | 08:25 AM
SVOboy's Avatar
Yeap, the two ecus are the same, just make sure you take out the j12 jumper though. It sounds like you know what you're doing, so might as well DIY it.
Old Jan 19, 2006 | 03:02 PM
bburtonsk8r2's Avatar
what bout hondata for a p13 ecu? i have a oddball car kind of, 92 lude si 4ws with jdm h22a conversion, how differenet is this from others?
jwyndsdime
Mar 26, 2007 07:25 PM
s2kkid
Aug 24, 2005 09:23 PM
B18Flip
May 29, 2004 07:12 PM
mugenintegra16
Nov 30, 2003 03:23 PM
crx1856
Aug 16, 2003 05:46 PM
