how hard of a push is 98 Newtons?
Old Feb 23, 2004 | 07:36 AM
Philip's Avatar
Default how hard of a push is 98 Newtons?
I'm trying to measure belt deflection, Helms says push on it with a force of 98 N (10 kgf, 22 lbf). Anyone know how hard this is?
Old Feb 23, 2004 | 07:57 AM
Jack Black's Avatar
Default Re: how hard of a push is 98 Newtons? (Philip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philip &raquo;</TD></TR><TR><TD CLASS="quote">I'm trying to measure belt deflection, Helms says push on it with a force of 98 N (10 kgf, 22 lbf). Anyone know how hard this is?</TD></TR></TABLE>
lbf = pounds of force...
Old Feb 23, 2004 | 08:10 AM
Philip's Avatar
Default Re: how hard of a push is 98 Newtons? (Agent Smith)
yes i know this, but does that mean i should push on the belt with my finger the same amount of force it would take for me to lift a 22 lb weight with my finger? I'm not that strong, so does this tell me to just push hard as I can?
thanks for the help
Old Feb 23, 2004 | 08:20 AM
Building_rice's Avatar
There aren't any gauges for pounds of push that I know of, but you could be creative and use a fisherman's weight scale that has a hook at the end. You'll definately be able to pull 22 pounds of force and the scale should be close enough to have you accurately mesure it.
Old Feb 23, 2004 | 04:26 PM
autoengineer07's Avatar
Default Re: how hard of a push is 98 Newtons? (Building_rice)
a newton is a unit of force , force is defined as Force = mass x acceleration, a 98 newton force is equivalent to approximately 22 lb of force which is a mild tension. as maybe a better rule of thumb go by the 90 degree rule, a belt should not be able to deflect an angle of more than 90 degrees
bds34
Sep 5, 2008 09:01 PM
v-tec maz
Nov 27, 2005 03:01 PM
Philip
Feb 23, 2004 08:36 AM
sytema
May 24, 2003 08:10 AM
Lei Siew Long
May 19, 2002 09:27 PM
