How do you remove a b16 head!
Old Mar 22, 2008 | 04:24 PM
Tru_Shine's Avatar
Default How do you remove a b16 head!
never mind eveything is fine. my dizzy just went bad
Modified by PandaMan at 5:03 PM 4/21/2008
Old Mar 22, 2008 | 06:20 PM
97grnrs's Avatar
Default Re: How do you remove a b16 head! (PandaMan)
why not start with the easier stuff. any check engine codes? if its not sparking removing the head will do u no good. and spark plug wear should have nothing to do with removing the head either. i would check the distributor and ecu, also main relay and check it timing belt jumped a tooth or more. then go to the head last. unless u broke valves or somthing no reason to pull head. and u take the rocker assemblys off first then u can get to the head bolts. and do a compression check on each cyl before u pull the head
Old Mar 22, 2008 | 07:32 PM
Tru_Shine's Avatar
Old Mar 22, 2008 | 07:35 PM
Tru_Shine's Avatar
Modified by PandaMan at 5:04 PM 4/21/2008
96ej8MR
Jun 27, 2007 05:37 PM
hotintegranights
Jan 4, 2003 11:40 AM
89 CRX SI
Sep 2, 2002 06:42 AM
mafioso102
Jun 20, 2002 12:16 PM
