How do you check engine codes
Old Mar 27, 2003 | 02:50 PM
sicklexus1's Avatar
Default How do you check engine codes
I have te codes but I forgot how to check them on my itr and gsr
[Modified by bonnieornelas, 3:53 PM 3/27/2003]
Old Mar 27, 2003 | 02:55 PM
poison's Avatar
Default Re: How do you check engine codes (bonnieornelas)
For OBD0 you just simply look at the LED on the ECU and count the blanks.
For OBD1 and 2 you need to grab a paper clip and bend it into a U shape. You then get the service connector under the dash (green rubber cover over it) and place the jumper paperclip into the harness with two wires in it.
You put the ignition on the ON position and count the CEL.
One long blink = 10
One short link = 1
So example, two long blinks and one short blink is 21.
HTH.
Old Mar 27, 2003 | 04:17 PM
orange.honda's Avatar
Default Re: How do you check engine codes (poison)
check this out http://www.c-speedracing.com/faq/06.php
this tells you exactly how
Old Mar 27, 2003 | 05:26 PM
sicklexus1's Avatar
Default Re: How do you check engine codes (orange.honda)
Thank you all very much
Old Apr 4, 2003 | 03:07 PM
Chiovnidca's Avatar
What if he has a model that doesn't have a service check connector?
Old Apr 7, 2003 | 08:17 PM
TEXN3's Avatar
Default Re: How do you check engine codes (TurboD16Chiovnidca)
i've been lurking here for a while, and i'm a member of http://www.g2ic.com
anyways, i don't know to much about the EK Civics. my friend has a 98 DX and he just told me the check engine light came on. i understand from reading this post of how to check the ecu(is it under the pass. seat?) and if someone could point me to a list of what the codes mean? my helms manual for the DA is in my trunk and my dad has my car in wyoming.
TIA.
Old Apr 7, 2003 | 08:35 PM
poison's Avatar
Only other model that doesn't have one is non-OBD 88-91 or OBD0. They have an LED on the ECU.
Old Apr 8, 2003 | 01:02 PM
Chiovnidca's Avatar
What about 1998 and newer Accords? Or 1999 and newer Oddyseys?
Old Apr 8, 2003 | 03:17 PM
dfoxengr's Avatar
jump the service connector or get CODE scanner$$$
madsk
Sep 12, 2017 04:06 AM
cor4ey
Dec 20, 2008 12:42 PM
spoon063
Jul 29, 2003 11:09 AM
lsvtec101
Apr 4, 2003 11:20 AM
1sick4door
Feb 25, 2002 07:46 PM
