How do you adjust alignments on Hondas?
Old Sep 24, 2001 | 04:22 PM
RaceBred's Avatar
New User
Default How do you adjust alignments on Hondas?
Hey hey...my alignments been off, and its beggining to bug a little. I have a sketchy idea on how to fix it, but does anybody know exactly how to align a 92 Civic Hatch? Isnt there something to do with adjusting the control arms?
Old Sep 24, 2001 | 06:45 PM
KekeK-18's Avatar
Default Re: How do you adjust alignments on Hondas? (RaceBred)
to adjust the toe (only thing that u can adjust) for civic. Look for a tie rod behind the front axles just turn the tie rod clock wise or anti clock wise to adjust. for the rear the is a arm that connects the trail arm to the chassi and by loosening the bolt that hold the arm to the chassi you can adjust the rear toe. Tape measure the different of the front and rear tire the get what ever setting you want.
Old Sep 24, 2001 | 07:37 PM
Sonic's Avatar
Default Re: How do you adjust alignments on Hondas? (b18cturbo)
It's tough to get it just right at home, without the laser things or a toe gauge. THe goal of alignment is to get the space between the fronts of the front wheels and the backs of the front wheels to have the same distance between them. If you measure off of the center of the tire (in the same places for all measurements) you can get very close. My Kumho 712's have a large center groove which makes it fairly easy. The goal in this is to adjust the tie rods so that both wheels are pointing EXACTLY straight down the road.
Old Sep 24, 2001 | 09:55 PM
RaceBred's Avatar
New User
Hmm..the tie rod behind the front axle? Can I get some visuals on this?
Old Sep 25, 2001 | 11:54 AM
Sonic's Avatar
Go look at your car or at your shop manual. IT will all become perfectly clear. THere is only one thing that attaches to the steering knuckle on the back (car rear) side of the hub. WHen you see it you'll know what I mean.
Old Sep 25, 2001 | 10:15 PM
clockworks's Avatar
Do civics have radius rods?
Old Sep 26, 2001 | 08:28 AM
Jared's Avatar
Default Re: How do you adjust alignments on Hondas? (clockworks)
only 88-91 civic/crx has radius rods
e.p
Sep 13, 2016 10:41 AM
MrMykl
Aug 5, 2016 04:45 PM
scheibler
Apr 22, 2016 10:20 PM
mrboompow
Suspension & Brakes
Oct 8, 2013 08:29 AM
young_tuner
Jan 22, 2010 05:29 AM
