how do u do valve seal gaskets
Old Sep 24, 2004 | 04:06 AM
ricekiller's Avatar
Default how do u do valve seal gaskets
hey guys im a honda noob and i would like some pointers on what u guys do when doin valve gasket seals. thanks any comments appreicated
Old Sep 24, 2004 | 06:37 AM
JimBlake's Avatar
Default Re: how do u do valve seal gaskets (ricekiller)
Not sure what you mean... Valve cover gaskets are pretty easy. Take off the valve cover, put on a new gasket (including the round seals for the spark plug tubes) & bolt it back on. Just don't over-tighten the nuts that hold it down. They break easily...
If you're talking about valve stem seals, that's entirely different. Maybe not a job for a noob?
Old Sep 24, 2004 | 06:52 AM
tgreaves's Avatar
I think he means valve stem seals.. Am I correct?
Old Sep 24, 2004 | 06:55 AM
tgreaves's Avatar
Default Re: how do u do valve seal gaskets (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">If you're talking about valve stem seals, that's entirely different. Maybe not a job for a noob?
Naaa... They are easy.. Just gotta make sure you do them correctly..
1. Remove the old valve stem seals with a pair of pliers(good luck, its a PITA)
2. clean the valve guide and make sure to remove the little rubber pieces on the outside of the guide that were left over from the old valve seal..
3. put a valve into the head on the seal your working on..
4. put a little oil on the valve stem and slide the seal down the stem of the valve..
5. use a deep well 10mm and tap the valve seal on to the guide, youll know when its on all the way..
v1crattlehead
May 30, 2008 07:09 PM
vinuneuro
Apr 24, 2007 06:05 AM
casmello
Jan 23, 2006 05:32 PM
1.8EG-T
Dec 14, 2003 02:56 PM
SpoonFedHatch
Apr 27, 2003 08:06 PM
