How Do I take these sensors off?
okay for the oil pressure switch, grab the center of the rubber boot and you will notice you grab onto a solid connector, sqeeze tightly and pull
once you have that one off, you have to get the fan switch ones off, those are harder without tearing the boot because there is 2 wires and u cant really grab it too well.
Take a flat head screw driver and pull the rubber boot back a little bit, then grab the rubber and pull.
The rubber tears easily, but its not the end of the world if it breaks.
JUST DONT PULL ON THE WIRE. always pull by the plug.
