how do i remove crank sprocket?
Old Mar 21, 2011 | 03:31 PM
408EJ1's Avatar
Default how do i remove crank sprocket?
i need help removing the crank sprocket on my gsr block. i removed the crank and the oil pump is still on the crank because the of the crank sprocket. can someone tell me how the sprocket comes off plz
Old Mar 21, 2011 | 05:55 PM
stumpyf4's Avatar
Default Re: how do i remove crank sprocket?
A bit of penetrating fluid between the crank and the sprocket and it should come right off. It's powdered metal so don't bang on it especially if it's an OBD2 one with tooth sensor wheel on the back side.
If it's stubborn use 2 screwdrivers between the sprocket and oil pump housing... gently.
Old Mar 21, 2011 | 06:38 PM
night's Avatar
heel bars
greyEG
16
May 22, 2013 01:38 AM
mar778c
Feb 4, 2007 07:14 PM
jackstands
Mar 13, 2005 08:54 AM
NERV
Sep 16, 2004 07:49 AM
