How can you tell the difference between a jdm engine and a usdm engine.
Old Nov 18, 2002 | 08:24 PM
Speed_Racer's Avatar
Default How can you tell the difference between a jdm engine and a usdm engine.
I am looking to buy a a jdm B16a engine for my honda civc cx. I want to know how do i tell the difference between the a jdm engine and a usdm engine. i have heard you can tell by the valve cover it is true and if so how do i tell
Old Nov 18, 2002 | 08:27 PM
mugenracer's Avatar
Default Re: How can you tell the difference between a jdm engine and a usdm engine. (Speed_Racer)
USDM valve covers have Honda Motor Company written at the botton, whereas JDM ones just have the emblem. B18 series engines will only have the engine number stamped as B18C, and USDM engines are stamped B18C1/B18C5, theres possibly other ways but i cant think of them
Old Nov 18, 2002 | 09:13 PM
incubus's Avatar
also the series number (under the engine code) if it is 1million or 4million something then it is a JDM. 1millions = from JDm integra Xsi
4millions= from civic or crx sir's.
I thought the the JDM ITR motors were stamped b18c5?
why do u only want a JDM?
I would take what you can get. besides the USDM b16a's make more power than the JDM's.
Old Nov 18, 2002 | 09:20 PM
sgT's Avatar
sgT
Default Re: How can you tell the difference between a jdm engine and a usdm engine. (mugenracer)
Easiest way.... JDM has NO number after the block code(ie b16a, b18c)
No ifs ands or buts, NONE have numbers
Old Nov 19, 2002 | 05:31 AM
Lysawy's Avatar
Default Re: How can you tell the difference between a jdm engine and a usdm engine. (incubus)
How u figure JDM has Les power USDM 160hp 111Tq , JDM 168HP 116Tq and jdm compression is up by 0.2 i think so how u figure .
Old Nov 19, 2002 | 07:30 AM
TruePlayaz114's Avatar
Default Re: How can you tell the difference between a jdm engine and a usdm engine. (Cx Sir II)
with USDM motors the DOHC letters are bigger than the VTEC letters. In a JDM the vtec letters are bigger than DOHC.
Old Nov 19, 2002 | 07:41 AM
ekb18c's Avatar
JDM ITR are just stamped b18c
And the JDM motors make more power then the US counterparts because compression on the motors are slightly higher.
Old Nov 24, 2002 | 07:22 AM
SargentNg's Avatar
If the jdm itr engines are stamped b18c, what are teh jdm gs-r engines stamped?
Old Nov 24, 2002 | 08:28 AM
chet's Avatar
Default Re: How can you tell the difference between a jdm engine and a usdm engine. (SargentNg)
b18c
Old Nov 24, 2002 | 08:41 AM
chet's Avatar
Default Re: How can you tell the difference between a jdm engine and a usdm engine. (chet)
also, distinguishing a motor by its valve cover is not always reliable...as a valve cover can be switched with relative ease. i've found the best way to tell a USDM motor from JDM motor is the stamping on the block...ie b18c vs b18c1 etc and the way the wiring harness is mounted on the motor. chances are, if the motor has b18c stamped on it and its wiring harness is setup for right hand drive then its from jdmland, or another country where they receive the same motors...etc.
plus, you can be sure you have a jdm motor when your rings are shot and it burns oil!
Old Nov 24, 2002 | 09:44 AM
denshu's Avatar
Default Re: How can you tell the difference between a jdm engine and a usdm engine. (sgT)
sgt my jdm b16 have a2 on it?
but it was from a right hand drive car?
could it be from another asian country ?ie hong kong?
Old Nov 24, 2002 | 10:08 AM
chet's Avatar
Default Re: How can you tell the difference between a jdm engine and a usdm engine. (denshu)
are you sure your b16a2 wasn't from a civic si.
i'm willing to bet thats what you have.
Old Nov 24, 2002 | 10:32 AM
Nameless RB26's Avatar
Look for a vtec pressure switch too, jdm engines don't have that.
As for the valve cover stuff, the USDM B16 valve covers look like the JDM ITR valve covers, only different colors.
The JDM ITR valve covers do not look like USDM ITR valve covers.
Old Nov 24, 2002 | 10:34 AM
I'm willing to bet that too. It seems that a good amount of people on this board think their engine is JDM when it has a suffix on it... and it's not.
Old Nov 24, 2002 | 11:31 AM
denshu's Avatar
Default Re: How can you tell the difference between a jdm engine and a usdm engine. (Nameless)
here are some pics
tell me if it is or not thx
Old Nov 24, 2002 | 11:35 AM
It's not. There's a vtec pressure switch on it, and it says A2.
Sorry dude..
it's not a big deal though, usdm engines have alot of pros.
Old Nov 24, 2002 | 12:41 PM
10K2HVN's Avatar
Actually, the JDM ITR motors are B18C4's... C5 is the knock off USDM version (tuned down version)...
..of course its not stamped on there tho...
[Modified by 10K2HVN, 9:46 PM 11/24/2002]
Old Nov 24, 2002 | 12:55 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: How can you tell the difference between a jdm engine and a usdm engine. (10K2HVN)
heres my USDM b16 see if you can tell the difference between yours ..
Old Nov 24, 2002 | 02:05 PM
denshu's Avatar
Default Re: How can you tell the difference between a jdm engine and a usdm engine. (CiRcUiTsi)
it is a b16a2..you can't really see the 2 in that pic..
looks like the intake manifold is a little differnt and also the tranny..i got no stamp but just the sticker, and you got that metal plate with numbers
[Modified by denshu, 3:06 PM 11/24/2002]
Old Nov 25, 2002 | 12:01 AM
Where the hell do you see the b16a2??? It looks like b16a to me and all vtec motors have a vtec oil pressure switch!!!!!!
maybe something is wrong with my eyes, but they're telling me there is a "2" there. You should take another look.
And NO, not all dohc vtec engines have pressure switches. Mine sure doesn't, and I wouldn't have a plug dangling off my usdm engine harness there if I did. My p28 wouldn't be throwing a code for it either.. and I might actually be able to engage in vtec if I had one. That leaves me to believe I don't have one. Can you prove me wrong?
I can see one on that engine, it's there.
[Modified by Nameless, 1:09 AM 11/25/2002]
Old Nov 25, 2002 | 12:07 AM
JDM ITR is stamped B18c. B18c nothing. Just like all other JDM DOHC Vtec engines.
Old Nov 25, 2002 | 12:59 AM
pissedoffsol's Avatar
25 Year Member
i see the 2 as well-- 99-00 civic si.
and as for JDM motors NEVER NO IFS AND OR BUTS about the trailing number, there is one exception:
Old Nov 28, 2002 | 11:15 PM
Default Re: How can you tell the difference between a jdm engine and a usdm engine. (hndarcr)
Man please someone else jump in on this one but every dohc vtec motor Ive ever put in a car has had a vtec oil pressure switch and Ive put in hundreds!!!
hundreds? lol ok then. You obviously aren't looking in the right place.
Old Nov 28, 2002 | 11:29 PM
On a JDM engine, that pressure switch is not even part of the harness. There is a hole. That's it.
Old Dec 3, 2002 | 01:17 AM
Raz1983's Avatar
These are real jdm b16 (Out of a Civic Ferio)
