How to bleed the clutch.....HELP NEEDED FAST
Old Jun 1, 2003 | 03:48 PM
riceburnah's Avatar
Default How to bleed the clutch.....HELP NEEDED FAST
95 CX
Need to know how to bleed the clutch, i just swapped the motor, and need help.
Thanks
Old Jun 1, 2003 | 03:59 PM
JCushing's Avatar
Default Re: How to bleed the clutch.....HELP NEEDED FAST (ihaterice8)
same way you bleed brakes... put the bleeder hose on the clutch bleeder nipple, put it in brake fluid, add brake fluid to the clutch cyl, loosen the bleeder nipple, and squeeze the clutch in till air bubbles stop coming out. tighten the bleedre nipple. make sure you dont run out of clutch fluid though its a real small resivour.
Old Jun 1, 2003 | 04:36 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ihaterice8 &raquo;</TD></TR><TR><TD CLASS="quote">95 CX
Thanks</TD></TR></TABLE>
http://www.helminc.com
Old Jun 1, 2003 | 05:10 PM
97hb's Avatar
I put some hose on the end of the nipple, submerge the hose in brake fluid, make sure the resorvor has enough fluid. I then have someone push the clutch to the floor and hold it there while I open the nipple and it squirt out . I then close the nipple and have the person pull the clutch pedal off the floor(it gets stuck up there). I repeat this process untill a steady stream of fluid comes out.
Prelude4ws
Nov 28, 2006 06:19 AM
Luchini
Oct 16, 2005 06:06 PM
Apocolipse269
10
Sep 3, 2004 08:06 AM
Team 4R
Jan 13, 2004 04:16 AM
blklude
Jun 16, 2003 10:08 PM
