How to adjust cam gears
what gears are you using? it should be marked.
http://www.hondaswap.com/articles/viewer.php?id=28
that may help
that may help
i know how to adjust them.. I am just not sure which way to rotate the cam gears for advancing or retarding..
Do i rotate clockwise when advancing the intake cam?
Do i rotate clockwise when advancing the exhaust cam?
Just answer each question with a yes or no, then i can figure it out. Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 »</TD></TR><TR><TD CLASS="quote">Advance = Clockwise
Retard = Counter Clockwise
If you are not using adjustable cam gears, each tooth is 20 crank º.
Modified by psi420 at 12:47 PM 4/10/2003</TD></TR></TABLE>
http://godspeed.hack.net/camgeardirections.html has the other way around.
I read it off of my CAM GEAR on my car.
That is an AEM Cam Gear BTW.
Want a picture?
Quote from Website you posted:
This is how the belt and gears will look once installed. Belt moves in counter-clockwise direction. Moving outer gear towards the right will advance cam timing and moving outer gear to left will retard. Always remember to reset timing when adjusting intake gear.
Want a picture?
