how-to 99 climate control
Old Nov 25, 2008 | 02:08 AM
yurmom562's Avatar
Banned
Default how-to 99 climate control
well i have a ek shell that im doing 99 conversion
and im wondering if anyone knows what i need to do to make the 99-00 climate control work on the 96-98 chassis
any help will be repayed for
Old Nov 25, 2008 | 05:57 AM
LA_HONDAS's Avatar
dont do unless you have a 99-00 to strip as you work
you change the dash and engine harness to 99-00 well just put it this way you gotta change all harness from the taillights to the headlights you gotta change the dash to 99-00 you gotta change the heater core box to 99-00 its not that simple as changing the climate control
so if you wanna do fine you a 99-00 civic and strip it
been there done that and dont wanna do it again
Old Nov 25, 2008 | 10:29 AM
yurmom562's Avatar
Banned
Icon2
well i have the heater core and the complete underdash with the wiring
is there away that i can make it work with just that?
or is it a must to convert everything to 99-00 :l
Old Nov 25, 2008 | 11:39 AM
LA_HONDAS's Avatar
if you got the 99-00 dash harness then you engine harness to go with it
96-98 engine harness have 3 ecu plugs on it
99-00 engine harness have 2 ecu plugs on it and the other one is on the dash
rywire should beable to convert the 96-98 dash harness to 99-00 if you him send both of them, you should pm him
Old Nov 25, 2008 | 12:58 PM
yurmom562's Avatar
Banned
Post
so basically have to convert the chassis to obd2b?
thanks for the help
Old Nov 27, 2008 | 12:17 AM
STOCK_SOHC_DX's Avatar
I have no idea why you would need to switch to that 3 to 2 plug harness. I had to replace the heater core and blower motor and used the 99 dash harness and everything works I don't remember how many plugs there were but I did have the whole 00 si dash so I threw that in as well.
ONEcam
Apr 6, 2015 05:52 AM
sii.
Jun 23, 2012 03:27 PM
VjaSMine
Dec 27, 2009 07:18 AM
4drferio
Jun 8, 2007 08:27 PM
4drferio
Jun 7, 2007 02:43 AM
