electrical problem, crazy sounds coming from engine bay and main relay
Old 08-29-2005, 03:52 PM
fullraceacura's Avatar
Default electrical problem, crazy sounds coming from engine bay and main relay
so recently i dropped a swap into a 94 cx hatch that was stolen and stripped a year and a half ago, it started fine a couple times, then it sat for a few days waiting for its time to get the exaust and radiator put on, but now when i turn the key to the on position, nothing will happen(like the fuel pump wont prime) for 5-10 seconds and then, there are some crazy popping and crackling sounds come from (i think) the main relay under the dash and in the engine bay somewhere by the intake manifold.
this is one of those desperate and in need times of help posts, sorry im trying to describe as best i can right now, sorry for shitty grammar
Old 08-29-2005, 04:12 PM
Default Re: electrical problem, crazy sounds coming from engine bay and main relay (itr#xxxxlives)
now its not making any noises but the fuel pump wont prime, the cel wont blink, and so ofcourse it wont start
Old 08-29-2005, 08:54 PM
civic_driver's Avatar
Did you check out the main relay if the solder points are okay? If they are not, I would resolder them over and try starting the car then.
Seems like something is shorting out (probably main relay as you put it).
Brand
21
09-08-2022 09:39 AM
ckirso
03-18-2013 08:08 AM
oakpwr
01-20-2007 12:05 PM
Kasper.
09-25-2002 07:26 PM
serious
09-02-2002 05:38 PM
Quick Reply: electrical problem, crazy sounds coming from engine bay and main relay
