Horse Power bolt-on's
I have a 98 LS Integra and of course I want it faster. I've already done some of the no brainers like added a cold air intake, headers and I have a intake manifold I need to put on. I also plan on getting cam gears soon. Now I'm not looking to dump a **** load of cash on a turbo, which would be nice.
I'm just looking to know what the basics are. Like if a new, more powerful, fuel pump would get me some power along with fuel pressure regulator and fuel rail? stuff like that. Stuff that's not too expensive and add a little power.
Thanks for the help.
Cam gears will not add any hp.Neither will any fuel pump,fuel rail , or fpr.Your next steps would be more compression,bigger cams and engine management.
Glenn
Glenn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bloodline_ls »</TD></TR><TR><TD CLASS="quote">Adjustable cam gears don't add any power? Then what do they do?</TD></TR></TABLE>
you should've gotten cams to go along with those cam gears and something to tune with. then you would see power gains.
What kinda of cam's should I get? Also I live in California so preferably something that would still let my car pass smog. Also what do I use to tuen them with?
Modified by bloodline_ls at 8:10 PM 3/26/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bloodline_ls »</TD></TR><TR><TD CLASS="quote">What kinda of cam's should I get? Also I live in California so preferably something that would still let my car pass smog. Also what do I use to tuen them with?
Modified by bloodline_ls at 8:10 PM 3/26/2005</TD></TR></TABLE>
see what http://www.crower.com has to offer. dont forget to upgrade the valvetrain if you get to big a set of cams. you can tune with with a safc if you want to keep it simple.
if u dont wanna spend big money on turbo then do a homemade turbo...if u dont want the headache of putting it together n tuning have a shop do it but then again u run into the money problem...so ur wnting to stay n/a could get expensive to...I/H/E is always a way to start n/a personaly i say save up a lil and go with turbo but...if u dont mind goin n/a than i/h/e is ur best bet...after u got that out of the way try a larger aftermarket throttle body for more air and better throttle response...then go with intake mani...Or ITB's is another way to go(do a search on ITB's)....after u got the flow out of the way invest in a nice set of cams and then cam gears to benifit the cams... then try increasing ur compression with some new pistons....now once u have some acctual hp gains going on u are goin to need the new fuel pump, high flow filter,fpr, fuel rail and injectors to benifit your new setup....then u can go on to new tranny(diff gearing), flywheel(increases throttle response and rotational mass thus getting up to high rpms quicker).
then again u can go nitrous which i dont recomend but it does give u the best bang for ur buck 400-500 buks for 50-75 hp
this will of course rack up in terms of cash but this is the only way u will get any good noticable power gains off a n/a setup
then again u can go nitrous which i dont recomend but it does give u the best bang for ur buck 400-500 buks for 50-75 hp this will of course rack up in terms of cash but this is the only way u will get any good noticable power gains off a n/a setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackbmagic »</TD></TR><TR><TD CLASS="quote">...after u got that out of the way try a larger aftermarket throttle body for more air and better throttle response... </TD></TR></TABLE>
Ok I already have a skunk2 Intake manifold for my 98 Integra LS and I've been looking to upgrade the throttle body with it. I found a throttle body from a 98 JDM Honda CRV 2.0L automatic for $50. Very clean. Should this be able to fit on my 1.8L Integra manifold and give me better air flow? Or is it not going to fit or just be a waist of money? Also my car is a stick if that makes a difference
Remember to set aside some $$ for dyno time. Getting some real world numbers will allow you to see where you're at and just how much or little all those parts have helped you.
flywheel, b16tranny w/ls5th,that should make you faster than any bolt ons. (for the money)btw you did not mention if you had exhaust system just "header(S)"lol, if not then that, + b16 tranny wont mess w/ emissions
When your engine is modified to the point that your cam timing needs to be changed then youll need adjustable cam gears.. But on a stock motor all you can really do with them is move the torque curve with them..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bloodline_ls »</TD></TR><TR><TD CLASS="quote">Ok I already have a skunk2 Intake manifold for my 98 Integra LS and I've been looking to upgrade the throttle body with it. I found a throttle body from a 98 JDM Honda CRV 2.0L automatic for $50. Very clean. Should this be able to fit on my 1.8L Integra manifold and give me better air flow? Or is it not going to fit or just be a waist of money? Also my car is a stick if that makes a difference</TD></TR></TABLE>
Does anyone think I should go with this or not?
m_wrx
May 31, 2010 03:13 PM
