Hondata S200 Install Problem
Old Aug 11, 2006 | 05:04 PM
ALL MOTOR EM2's Avatar
Default Hondata S200 Install Problem
My Friend recently purchased a S200 P72 GSR ECU off a guy on K20a.org. We went to to fire up the car so he can pass emissions and it wouldnt fire up. Doesnt sound like its getting fuel. is there actually wiring that needs to be done or is it plug in and play? Also would it matter if the Launch control and full throttle shift are not hooked up? (it was too late to pick up the T-taps we needed for clutch sensor switch)
Modified by ALL MOTOR EM2 at 8:46 PM 8/11/2006
Old Aug 11, 2006 | 07:45 PM
Default Re: Hondata S200 Install Problem (ALL MOTOR EM2)
does anyone know what wire is what in the clutch position sensor for the launch control and full throttle shift??
Old Aug 11, 2006 | 09:47 PM
mtber's Avatar
You don't need to wire in any of the external options to get the car to run properly.
Go to hondata.com and download the s200 manual.
It will walk you through troubleshooting the s200 system.
justinCO
Nov 14, 2008 09:52 PM
obnoxiousls
Engine Management and Tuning
Aug 30, 2008 07:44 PM
TurboB16A300Hpteg
Jul 2, 2007 02:02 PM
2000GSRT
Feb 25, 2004 03:21 PM
MEANB18
Oct 14, 2003 06:03 PM
