Hondata Question
Old Apr 20, 2004 | 05:56 PM
98HB's Avatar
Default Hondata Question
I recently received my ECU from Hondata and was wondering if someone can guide me to place the chip and EPROM. I have a general idea but I want to make sure.
Thanks
Old Apr 20, 2004 | 06:11 PM
HRTuning's Avatar
Default Re: Hondata Question (98HB)
The s100 goes on that 4 pin header at the lower left corner of the pic... The 28-pin eprom goes in the 28-pin socket... Make sure the groove in the eprom is facing the same direction as the groove in the socket (toward the ECU plugs)
Old Apr 20, 2004 | 06:37 PM
98HB's Avatar
Default Re: Hondata Question (HardLowrdRanger)
Thanks!
Old Apr 21, 2004 | 05:54 AM
98HB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HardLowrdRanger &raquo;</TD></TR><TR><TD CLASS="quote">The s100 goes on that 4 pin header at the lower left corner of the pic... The 28-pin eprom goes in the 28-pin socket... Make sure the groove in the eprom is facing the same direction as the groove in the socket (toward the ECU plugs)</TD></TR></TABLE>
Other question, the s100 has about 8 pins underneath and there is only 4 on the header, so would I put it all the way to the right or to the left.
Old Apr 21, 2004 | 01:19 PM
98HB's Avatar
Bump
Old Apr 21, 2004 | 03:59 PM
dfoxengr's Avatar
theres an install manual on hondata.com
Old Apr 22, 2004 | 05:30 AM
98HB's Avatar
Default Re: Hondata Question (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">theres an install manual on hondata.com
I saw that but it dosen't say(show) exactly if it's over to the left or right of the 4 pin.
Old Apr 22, 2004 | 09:09 AM
dfoxengr's Avatar
here are some pics you most likely looked over that clearly show where it goes
http://hondata.com/manuals/s100/s100.html
Old Apr 23, 2004 | 06:00 AM
98HB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">here are some pics you most likely looked over that clearly show where it goes
Thank you very much for the find.
Blazin Si
Engine Management and Tuning
15
Apr 30, 2010 08:15 PM
B16Civic93
Feb 17, 2005 08:54 AM
NiceDc2r
May 19, 2004 07:52 PM
Sohc Driver
Nov 18, 2003 10:18 AM
glagola1
Aug 22, 2003 08:51 PM
