Hondabond a must use?
Old Jul 1, 2007 | 09:53 AM
Liquidgsr's Avatar
Default Hondabond a must use?
Im doing a cam install wondering if have use hondabond on the cam caps at the cam gear side or can i use any other silicone gasket sealer? I also need to use it on my coolant line where the coolant goes from the engine to the radiator on top. Its leaking and i need to put a new seal on it.
Old Jul 1, 2007 | 10:02 AM
non-VTEC's Avatar
Default Re: Hondabond a must use? (Liquidgsr)
as long as its a good RTV silicone sealant it will work just fine.....
Old Jul 1, 2007 | 11:04 AM
Padawan's Avatar
Darth ModerVader
Permatex Ultra Grey is the generally agreed-upon substitute for Hondabond and is available at almost any auto parts store.
Old Jul 1, 2007 | 11:47 AM
MidwestCivic's Avatar
what about the ultra copper high temp, i heard that is a little better
Old Jul 1, 2007 | 01:23 PM
sauceja's Avatar
Default Re: Hondabond a must use? (Padawan)
Hondabond or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Permatex Ultra Grey is the generally agreed-upon substitute for Hondabond and is available at almost any auto parts store. </TD></TR></TABLE>
Old Jul 1, 2007 | 01:47 PM
EmminoDaGreat's Avatar
Default Re: Hondabond a must use? (sauceja)
I wouldnt use the copper on cam caps. Hondabond or the Permatex Ultra grey, the grey is for aluminum on aluminum contact so it works best. But im sure the Ultra black would work fine.
Old Jul 1, 2007 | 03:12 PM
Liquidgsr's Avatar
Default Re: Hondabond a must use? (EmminoDaGreat)
yeah i think i saw ultra black but not ultra grey.
Old Jul 1, 2007 | 04:22 PM
I dont get it, isnt the copper for aluminum too? Thats all I have been using so far
Old Jul 1, 2007 | 05:09 PM
Default Re: (MidwestCivic)
I usually use the copper for exhaust manifolds, high heat places.
Old Jul 2, 2007 | 07:02 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestCivic &raquo;</TD></TR><TR><TD CLASS="quote">I dont get it, isnt the copper for aluminum too? Thats all I have been using so far</TD></TR></TABLE>
The Copper should also work well, and has higher heat tolerance.
MidShipCivic
Welding / Fabrication
27
Jun 3, 2007 08:00 PM
sohc_boy
10
Aug 22, 2005 12:32 PM
B16Civic93
Feb 18, 2005 07:56 PM
oMek
Dec 29, 2003 07:58 AM
