Honda-Tech Engine Parts glossary
Old Apr 28, 2005 | 11:13 AM
JDMKiddo's Avatar
Default Honda-Tech Engine Parts glossary
I only know some stuff about the parts in an engine. I would like to know if we can make a glossary with the definition of the engine part and a picture so people can know what your talking about.
:::Example:::
Pistons - 1. An engine part that reciprocates in the cylinder and transfers the force of the expanding gases via the piston pin and connecting rod to the crankshaft.
2. A round, caliper component in a disc brake that is moved outward by fluid pressure to press the pads against each rotor face.
Picture -
Old Apr 28, 2005 | 03:08 PM
JDMKiddo's Avatar
bump c'mon
Old Apr 28, 2005 | 05:39 PM
rjay8604's Avatar
Default Re: (JDMKiddo)
hmm, i think there already plenty of this info. It is scattered though. The service manual will cover everything though.
Old Apr 28, 2005 | 09:31 PM
zacdaddy77's Avatar
Default Re: (rjay8604)
The gas peddle
(1)the peddle on the far right that you mash to the floor when you see a mustang (trying) to pass you
(2) the peddle on the far right that you let off of and say oh **** when you see a cop
( this is really a good idea though I'm just a smart ***)
Old Apr 29, 2005 | 04:58 AM
JimBlake's Avatar
Default Re: (zacdaddy77)
Good idea. How about a glossary of misused/misspelled terms that are popular around here?
Dizzy = when you drive around in circles too fast.
Ignitor = that thing in the dashboard for lighting cigarettes.
Peddle = that thing near the floor, us old-farts call it a pedal.
Break = brake (or is it broken??)
Won't crank = won't fire (depending on who's writing).
Won't fire = won't crank (depending on who's writing).
Engage the clutch = press down the pedal (depending on who's writing).
Engage the clutch = let up the pedal (depending on who's writing).
Double-clutching = rev-matching (or maybe it means simply revving the engine?)
Short = open-circuit (depending on...)
"How can I test" = "I don't own a meter, so I want you to guess" (depending...)
Bigal04
May 4, 2016 10:05 AM
darkirony
May 31, 2004 01:46 PM
ALF
Jul 29, 2002 01:38 AM
ActiveAero
Feb 21, 2002 09:13 PM
accordfreak
Feb 4, 2002 03:59 PM
