HONDA SMX B20B VTEC HELP
Old Nov 6, 2007 | 07:41 PM
hondasmx's Avatar
Default HONDA SMX B20B VTEC HELP
OK.looking for some help and info, i have a 97 honda smx with the b20b and standard auto transmission.I have a b18c vtec head reading and waiting to fit, but as my car didnt have a vtec in the first place my ecu which is a p8r wont control it.i cant find anything about which ecu i can use and will fit or if it will be ok with the auto tranny.!! Can anyone help??
[IMG][/IMG] IMG] heres a pic of the troubled car so far.!!http://i225.photobucket.com/albums/dd66/ohsofatcock/cid_y1NBGGG6hq.jpg[/IMG]
Old Nov 6, 2007 | 11:31 PM
Fezzie's Avatar
Default Re: HONDA SMX B20B VTEC HELP (hondasmx)
auto p72 is what you need
Old Nov 7, 2007 | 12:57 AM
Katman's Avatar
ah the SMX...
can you post a few images of your P8R ecu? namely, the ecu plugs.
Old Nov 7, 2007 | 01:41 AM
hondasmx's Avatar
Default Re: HONDA SMX B20B VTEC HELP (Katman)
yer ok i will get one done and post it, the full code is37820 p8r 911 817105105, so will the p72 ecu plug straight in you think?
Old Nov 7, 2007 | 01:59 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasmx &raquo;</TD></TR><TR><TD CLASS="quote">yer ok i will get one done and post it, the full code is37820 p8r 911 817105105, so will the p72 ecu plug straight in you think?</TD></TR></TABLE>
not unless you have a 4-connector/plug ecu.
THe JDM Auto P72 use a 4-plug ecu connectors as seen here:
If you have a 3 plug ecu, you might need to run a JDM P30 (B16A/SIR) ecu instead.
Old Nov 7, 2007 | 02:06 AM
hondasmx's Avatar
heres a pic of the plug end of the p8r ecu it has four plugs
i cant see how the p72 would fit as it only has 3 plug spaces as i would have a plug spare??
Old Nov 7, 2007 | 02:09 AM
hondasmx's Avatar
brilliant, that looks the same as mine then, which car does this come out of then so i know were to look, and one other thing i have thought of, i need to run a cable to the vtec control valve from the ecu, any idea whick terminal it would be
Old Nov 7, 2007 | 02:10 AM
hondasmx's Avatar
IMG]http://i225.photobucket.com/albums/dd66/ohsofatcock/cid_y1NBGGG6hq.jpg[/IMG]
heres the culprit car
Old Nov 7, 2007 | 02:55 PM
BlackLudeSi's Avatar
heres the culprit car</TD></TR></TABLE>
there you go
Old Nov 7, 2007 | 06:55 PM
-DC2-'s Avatar
oh snap, that's hot!
Old Nov 8, 2007 | 12:06 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasmx &raquo;</TD></TR><TR><TD CLASS="quote">IMG]http://i225.photobucket.com/albums/dd66/ohsofatcock/cid_y1NBGGG6hq.jpg[/IMG]
AUTO JDM Integra SiR/SiR-G.
Old Nov 8, 2007 | 09:40 AM
hondasmx's Avatar
hey cheers for that, do you know what years that may be, as here in the uk auto integs are veryu rare also, is there any others you may know of that will fit? what do you think about the vtec wire i will need from the ecu to my vtec valve, will i find it ok? cheers for all the info to.
Old Nov 8, 2007 | 09:53 AM
hondasmx's Avatar
ok i have found some on ebay usa site, but unsure as to which is a auto ecu even though they show the code number in the picture, or am i assuming that au means auto box? cheers for the help here.
Old Nov 9, 2007 | 01:31 PM
hondasmx's Avatar
does anyone know if the b20 intake will fit the b18c4 head? or will i nedd a b18 intake?
Old Nov 14, 2007 | 01:14 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasmx &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know if the b20 intake will fit the b18c4 head? or will i nedd a b18 intake?</TD></TR></TABLE>
no it will not fit. Non VTEC B20 and B18A/B manifolds are compatible with each other, but the B18C4 is equivilent to a US B18C1 manifold and is only design for a P72 head.
You can purchase a skunk2 manifold for B18A/B tho if you wish to go with a Type-R style intake manifold...
Old Nov 14, 2007 | 07:56 AM
hondasmx's Avatar
thanks for that, so what intake manifold am i looking for? a b18c same as the head you think? cheers
Old Nov 14, 2007 | 10:50 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondasmx &raquo;</TD></TR><TR><TD CLASS="quote">thanks for that, so what intake manifold am i looking for? a b18c same as the head you think? cheers</TD></TR></TABLE>
yes either a JDM B18C from an integra SiR-G (not a JDM B18C Type-R), or from a US B18C GSR engine. Or you can go aftermarket and run the Skunk2 manfold for B18C P72 head.
Old Nov 14, 2007 | 11:09 AM
LastGenEK's Avatar
use any civic ex auto ecu P2T 0BD2 OR THE PO6 EX AUTO
Old Nov 14, 2007 | 01:14 PM
Katman's Avatar
Default Re: HONDA SMX B20B VTEC HELP (LastGenEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LastGenEK &raquo;</TD></TR><TR><TD CLASS="quote">use any civic ex auto ecu P2T 0BD2 OR THE PO6 EX AUTO</TD></TR></TABLE>
He probably can't because his ecu uses a 4-plug ecu simliar to the jdm AUTO GSR ecu image i posted above.
Cresendo
Oct 3, 2021 02:36 PM
stivic
Dec 12, 2006 10:43 AM
dthug
May 2, 2006 12:44 PM
_Keith_
Mar 24, 2006 05:48 AM
darkshadowcivic
Dec 20, 2004 11:58 AM
