Honda MTF or GM syncromesh
Old Apr 3, 2005 | 05:15 PM
Ahknodd's Avatar
Default Honda MTF or GM syncromesh
Hey everybody!
I just did a massive search on Tranny fluids on H-T and I'm still not sure which I should go with. I'm going to be putting in a JDM ZC tranny into my 90 Hatch and I want to be sure to keep it running strong. I used regular multi grade oil (can't remember which brand) and then I switched to Royal Purple Syncromax and it ate up my tranny.
I heard that people swear by Honda MTF. And others say that it's not the best for hard driving or racing.
People mentioned that the GM stuff is great for the syncros, but is more expensive. And others say it's not as good as the Honda MTF.
I drive my car hard daily. On the street I rip through first and sometimes second. And I'm at the track almost weekly. So I need something to hold up that abuse.
Please help with anything...
Old Apr 3, 2005 | 05:47 PM
PrettyLude's Avatar
both are good, depends on person preference
Old Apr 3, 2005 | 06:39 PM
Ahknodd's Avatar
Default Re: (PrettyLude)
Well what do you prefer then and why?
Old Apr 3, 2005 | 10:23 PM
PrettyLude's Avatar
i've always used oem mtf, but imma try the gm synchromesh soon though
Old Apr 3, 2005 | 10:37 PM
tianporn's Avatar
I heard ELF 75W90 is really good.
Old Apr 3, 2005 | 11:44 PM
IT'S ME DAVID's Avatar
NooB
Default Re: (tianporn)
i posted a tread about this and about 85% of the people that replied said that gm synchromesh is better.
Old Apr 4, 2005 | 05:38 AM
civicross's Avatar
Default Re: (b20vtecallmota)
I've had excellent results with Redline MTL.
Old Apr 4, 2005 | 05:57 AM
tgreaves's Avatar
Default Re: (civicross)
Honda mtf works great for me.. On my old crx dx tranny, it started to grind a little into 2nd so I drained the tranny and put GM Syncromesh FM into it and it stopped the grind after like 10 miles..
I would say Honda MTF for good working trannies and GM Syncromesh FM for grinding trannies..
Old Apr 4, 2005 | 09:51 AM
redzcstandardhatch's Avatar
something different
the parts guys at my local honda dealership say that honda MTF is just
"slightly more expensive 10w30, its the same damn thing"
thats why it works fine for good trannies. 10w30 works identially.
Old Apr 4, 2005 | 11:13 AM
civicross's Avatar
Default Re: (redzcstandardhatch)
No, 10w30 will NOT work the same as a proper transmission fluid. It does not have the proper additives to work with the syncros correctly.
Old Apr 4, 2005 | 12:02 PM
jdmsijdm's Avatar
i use synchromesh and everyone that has driven my car can't believe how smoothly it shifts. It took about 2 or 3 weeks after initially putting it in but it got rid of my 3rd and 4th gear grinds. If you are going with a tranny that is already in good working order you might want to stick with the honda oem, then switch to the gm synchromesh if needed. As far as it being too expensive, it cost me about 35 dollars to put the synchromesh in myself, I dont see that as being too expensive if it makes my **** work better.
Old Apr 4, 2005 | 03:09 PM
PupaScoopa's Avatar
Default Re: (jdmsijdm)
Go with the Synchromesh, you'll love it!
Old May 5, 2005 | 09:59 AM
dornon13's Avatar
Default Re: (PupaScoopa)
are you guys using syncormesh or the synromesh FM?
RemerLex11
Jun 22, 2011 05:08 PM
egizzle8
35
Aug 7, 2003 08:13 PM
importboi22
Mar 27, 2003 08:33 PM
ITR1071
Oct 3, 2002 04:11 PM
Tommy_Gunns
Sep 24, 2002 01:59 PM
