Honda CRV Revving in Neutral
Old Dec 19, 2014 | 07:55 AM
accerat's Avatar
Default Honda CRV Revving in Neutral
Hey guys,
Looking for some help troubleshooting my 2002 CR-V. In the summer I overheated the engine, and I had the heads removed and machined (they were warped). It was sitting without being run for probably 3-4 months before it all got put back together. I put in new oil and a new filter (the oil was milky from water leakage) and now it's doing this...
Any idea what might be going on? I'm wondering if either the Head wasn't repaired fully, or if it had just been sitting for so long, or if maybe I put on the air filter/intake area wrong, but I'm not experienced enough yet to know for sure what's going on
Old Dec 19, 2014 | 09:04 AM
v4lu3s's Avatar
RTFM
Default Re: Honda CRV Revving in Neutral
DId you replace all teh gaskets for the intake when you put the head back on? it sounds as if you have a HUGE leak on the intake side.
Old Dec 19, 2014 | 09:42 AM
accerat's Avatar
I bought all new gaskets. Also it revs up to 2500 and then down to 1000. And if I pump the gas once in neutral it will change to revving faster and to 2000 instead
The guy who put the head itself in said "Ask him about number one cyl exhaust lobe having flat spot from metal transfer and them saying it was ok to use as well."
Old Dec 19, 2014 | 10:35 AM
v4lu3s's Avatar
RTFM
Classic vacuum leak signs. Air is getting past a gasket between the throttle body and head.
Old Dec 19, 2014 | 10:42 AM
accerat's Avatar
Do you think this could be due to the flat spot or would it definitely be from when it was put back together?
Old Dec 20, 2014 | 01:57 AM
v4lu3s's Avatar
RTFM
I think it has nothing to do with a flat spot, when an engine revs like that it is due to air coming in, if the throttle is closed it has to come from somewhere. If you paid someone to assemble it, they should be at your side helping look for the leak.
You also should make sure the idle is set correctly as well, I recommend following the service manual procedure on setting idle per the ecu you are using.
If you don't have a service manual, get one.
Old Dec 23, 2014 | 07:08 AM
accerat's Avatar
Update - I took it to a shop, they said it's the Cam Sensor
Tyte-S
Sep 24, 2007 06:46 AM
barney510
Mar 8, 2006 09:23 PM
KiDSoL
Acura TL, RL & ZDX
Jan 4, 2004 12:09 AM
