Honda Compression calculator accuracy
Old May 12, 2013 | 07:23 PM
Tkymik's Avatar
10 Year Member
Default Honda Compression calculator accuracy
I'm a bit confused about honda compression calculators.. I was checking some aftermarket pistons for my b18c type r and input the specs of the pistons into the calculator and the results came out wrong. Example the aftermarket piston had a 8cc dome, 30mm comp height and it should be 12.5:1 cr. But on the calculator it was only 11.8:1. I used zealautowerks calculator and the honda compression calculator app from my android phone both showed 11.8:1. So which is actually correct? Thanks
Old May 12, 2013 | 07:29 PM
doood's Avatar
been there done that
Default Re: Honda Compression calculator accuracy
they're general estimates. if you want to find out what your actual compression is do the measurements yourself and do some math.
Old May 12, 2013 | 07:34 PM
HiProfile's Avatar
The difference is the deck height between the GSR and LS blocks. The LS is actually a bit shorter, meaning it manages a bit more compression. That combo will produce 11.8:1 on a GSR block but 12.6:1 on an LS block, both figured with a GSR head.
Boosted_B_Series
Feb 13, 2009 07:45 AM
PinkMaggit
Dec 11, 2005 10:56 PM
junklr
May 12, 2004 11:31 AM
TeStUdO
May 5, 2003 05:28 PM
