high idle issue
Old Apr 14, 2011 | 04:53 PM
rhartman0922's Avatar
Default high idle issue
i have a del sol with a b18c1 freshly rebuilt and put back in the car....the problem im having is a high idle.
first when we put the motor back in it had a real bad sporadic idle but that has since gone away (after replacing the throttle body gasket) right after we replaced the gasket we were getting a leak from where the throttle body meets the intake manifold.
Now im not getting a leak from the throttle body anymore but the car is idling around 2000rpms, which I know is usually a vacuum leak.
My question is, the distributor still needs to be timed, I got a timing light today and plan to do it tonight, if the distributor is too far advanced or out of time could that cause it to idle high? Or should I keep searching for another vacuum leak along with timing it?
Old Apr 14, 2011 | 05:07 PM
Default Re: high idle issue
nevermind i found another leak on the throttle body....****. Well i put the new gasket on and its still leaking....so do you think RTV will help?
Old Apr 14, 2011 | 05:14 PM
ekcivicdreams's Avatar
damn my ***** doin that to but i got a b18a1 mines the iac valve
Old Apr 14, 2011 | 05:15 PM
get a new throttle body if it comes down to it
the_dxB16
Mar 13, 2008 10:47 PM
ridin98civic
10
Feb 2, 2007 11:11 AM
90AcuraIntegra04
Feb 4, 2006 02:18 PM
CRX_Control
Nov 7, 2004 07:47 PM
2fknlo
Sep 13, 2004 01:15 PM
