high idle...HELP!!!
Old Dec 8, 2003 | 05:32 PM
its WANG yoO's Avatar
Default high idle...HELP!!!
well i sprayed carb cleaner around my TB and the car idles the same...no raise at all...so i know now that there is no leaks there...i bleed my coolant system...the car is still idling at 1500-2500...no surging...just high idle...where it idles veries alot....if i unplug the TPS when idling at 2500 and plug it back in...it idles at 1500...until you shut off the car and restart...then its back to 2500...if i plug in my buddies P28 and jumper harness...the car idles at 700....whats up with this?
Old Dec 8, 2003 | 05:40 PM
Jimmy's Avatar
Global Moderator
Tried adjusting your idle screw on your IM?
Old Dec 8, 2003 | 07:35 PM
Default Re: (USDMDC2)
ok
Old Jan 29, 2004 | 11:23 PM
Default Re: (inJDMtegra)
bump
Old Jan 29, 2004 | 11:27 PM
hondatim's Avatar
what do you mean that you "plug P28 in and idles at 700 rpm"?
what ECU are you normally running on it?
just need a little more info...
Old Feb 1, 2004 | 05:41 PM
Default Re: (hondatim)
stock p75
Old Feb 9, 2004 | 11:18 AM
daddymaxx's Avatar
I have the same problem! I have a JDM b18c in my EK.
If I turn the idle screw ALL the way down it idles at about 1100, and cold starts at 1700.
But it the idle screw is set normal it ildes at lik e2000 and warms at 2600
Old Feb 24, 2004 | 10:43 PM
Ek9Max's Avatar
nobody?
ken2830
Jan 28, 2008 09:57 PM
viciousef9
Jun 18, 2007 03:18 PM
Chris N
Dec 4, 2003 09:40 AM
redman223
Jun 26, 2003 08:20 PM
