High Idle!?!?!
i just put a new headgasket and started the motor...it idles @ 4000 rpm...no check engine light and i checked the throttle cable...i also tried retarding and advancing the timing but no effect...what could be the problem???
Check and see if you have a vacuum leak by takeing of the intake and covering the throttle body with you hand. the motor should choke and shut of if it doesnt then you most likely have vacuum leak somewhere
allshownogo
Mar 25, 2008 12:15 PM
PhilMac
Jan 14, 2008 11:35 AM
Matt00
Nov 3, 2005 06:01 AM
