high idel, wtf?
Old May 25, 2003 | 03:48 PM
bluedelsol's Avatar
Default high idel, wtf?
my car is ideling prity high, like 1500-2000 rpms. i unpluged the Idle Air Control Valve (IAC) witch should have made it idel higher, but un-pluging it had no effect. the idel adjustment on the throttle cabel are set as low as posable and the idel adjustment screw on the throttle body is set right. could the Idle Air Control Valve (IAC) be bad?
Old May 25, 2003 | 06:56 PM
bluedelsol's Avatar
Default Re: high idel, wtf? (bluedelsol)
nobody knows? come on?
Old May 25, 2003 | 07:13 PM
.RJ's Avatar
.RJ
its sunday nite. relax.
Old May 25, 2003 | 07:26 PM
poison's Avatar
Is this when the car is warm?
Get some brake cleaner and clean out the IACV. Burp the water system by taking out all water bubbles in the system, also tighten the fast idle valve underneath the TB.
HTH.
Old May 25, 2003 | 08:11 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedelsol &raquo;</TD></TR><TR><TD CLASS="quote">my car is ideling prity high, like 1500-2000 rpms. i unpluged the Idle Air Control Valve (IAC) witch should have made it idel higher, but un-pluging it had no effect. the idel adjustment on the throttle cabel are set as low as posable and the idel adjustment screw on the throttle body is set right. could the Idle Air Control Valve (IAC) be bad?</TD></TR></TABLE>
Does putting your finger over the the IAC air port cause the idle to drop?
ShatiaNichols
Feb 24, 2012 05:02 AM
LOL@hondas
Aug 13, 2010 11:21 AM
blueDA9
Aug 24, 2007 05:21 AM
ATS*Mark
16
Feb 22, 2004 01:00 PM
ZeroGSR
Sep 10, 2003 03:42 PM
